%3CLINGO-SUB%20id%3D%22lingo-sub-504386%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EMehrere%20Fensteraufteilungen%20im%20Skripteditor%20zulassen%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-504386%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EIm%20Skripteditor%20h%C3%A4tte%20ich%20gern%20die%20M%C3%B6glichkeit%2C%20das%20Fenster%20aufzuteilen%2C%20damit%20ich%20drei%20oder%20mehr%20Abschnitte%20meines%20Codes%20gleichzeitig%20sehen%20kann.%20Das%20hei%C3%9Ft%2C%20wenn%20ich%20mit%20der%20rechten%20Maustaste%20auf%20die%20Zeilennummern%20links%20im%20Skripteditor%20klicke%20und%20%E2%80%9ETeilen%E2%80%9C%20ausw%C3%A4hle%2C%20m%C3%B6chte%20ich%20die%20M%C3%B6glichkeit%20haben%2C%20anzugeben%2C%20wie%20viele%20Aufteilungen%20ich%20haben%20m%C3%B6chte.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EOft%20muss%20ich%20drei%20oder%20mehr%20Codeabschnitte%20miteinander%20vergleichen.%20Das%20Hinzuf%C3%BCgen%20dieser%20Funktion%20w%C3%BCrde%20diese%20Aufgabe%20wesentlich%20vereinfachen.%20Ich%20hoffe%2C%20die%20Implementierung%20w%C3%A4re%20relativ%20einfach.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-504386%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAutomatisierung%20und%20Skripting%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-509985%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EBetreff%3A%20Mehrere%20Fensteraufteilungen%20im%20Skripteditor%20zulassen%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-509985%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EVielen%20Dank%20f%C3%BCr%20den%20Vorschlag.%20Derzeit%20haben%20wir%20im%20Skripteditor%20nur%20die%20M%C3%B6glichkeit%20f%C3%BCr%20eine%20Aufteilung%20und%20werden%20dies%20m%C3%B6glicherweise%20f%C3%BCr%20eine%20zuk%C3%BCnftige%20Version%20in%20Betracht%20ziehen.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Allow multiple window splits in the script editor
In the script editor, I would like to have the ability split the window so that I can see 3 or more sections of my code at once.  That is, when right-clicking on the line numbers on the left of the script editor and selecting "Split", I would like the option to specify how many splits I would like to have.
Often I find myself needing to compare 3 or more sections of code to each other.  Adding this feature would make this task much simpler.  I would hope implementing this would be relatively easy.
1 Comment
SamGardner
Level VII
Thank you for the suggestion.  We only have the ability for one split in the script editor currently, and we may take this under consideration for a future release.
