karlgrieshop
Community Member
Jul 17, 2013
zero-inflated poisson distribution in a generalized linear model
Is there a way to specify a zero-inflated poisson distribution (error structure) to a generalized linear model in the Fit Model platform?  I see I can specify normal, binomial, poisson, and exponential distributions; but what I need is a zero-inflated poisson distribution...  Any help greatly appreciated.  Thanks.
mewing
Jun 23, 2011
Re: zero-inflated poisson distribution in a generalized linear model
I don't know of a way to fit a ZI model of any type automatically.  I have always fit two part models, one part to model 0 or not 0 and a second to model the not 0 portion, then combined the models.
mattflynn
Oct 16, 2012
Clay Barker has a nice ZIPoisson example on the JMP File exchange..
// set up the ZIP negative log likelihood with the starting values defined above
Exform = expr(
ll << set formula(Parameter(
    {p = expr(pstart), lambda = expr(lstart)},
    If( :Y == 0,
        -Log( p + (1 - p) * Exp( -lambda ) ),
        -Log(
            (1 - p) * ((Exp( -lambda ) * lambda ^ :Y) /
            Factorial( :Y ))
// now plug the starting values into the negative log likelihood column
eval(eval Expr(exform));
// use nonlinear to minimize the negative log likelihood, which is equivalent to maximizing the likelihood
nl = Nonlinear(
    Loss( :NegLogLik ),
    Loss is Neg LogLikelihood( 1 ),
    Newton,
    Finish
