취소
다음에 대한 결과 표시
표시  만  | 다음에 대한 검색
다음을 의미합니까?
언어 선택 변환 막대 숨기기
wencun6
How to get a list of shortcut mapping?
anyway to get a list of the JMP shortcut mapping?
5 응답 5
Re: How to get a list of shortcut mapping?
What type of list do you mean? And of what shortcuts? Normal JMP shortcuts? Your custom shortcuts?
This has the normal keyboard shortcuts https://www.jmp.com/content/dam/jmp/documents/en/support/jmp18/keyboard-shortcuts.pdf .
wencun6
Custom shortcut list.
Here is the documentation for the keyboard shortcuts in JMP 18. If you're not on JMP 18 yet, here's the documentation for 17.2.
Ross Metusalem
JMP Academic Ambassador
wencun6
Thanks, i am actually looking for my customized shortcut list.
I think if you can figure out where your usercust.jmpcust file is located, you can parse that and get some sort of a list (not sure if it has all). It should be located somewhere around here (for windows) %AppData%\SAS\<jmpversion>\<jmpnumber> so for example for me it is %AppData%\SAS\JMPPro\17
추천 글
