BookmarkSubscribeRSS Feed
clark_woo-seag_
Jun 23, 2011
receive alphalevel as variable in Bivariate
I use Bivariate as below.
I want to receive alphalevel as variable.
biv=Bivariate(
Y( :X1 ),
X( :Y1 ),
Fit Line(
{Confid Curves Fit( 1 ), Line Color( "Green" )},
{Set α Level( 0.1 )}
8 REPLIES 8
Re: receive alphalevel as variable in Bivariate
Would something like this do what you need? I've annotated it to describe the various steps; to see the intermediate calculations, just uncomment the various comments I've inserted along the way. If you need a complete flexibility on alpha just replace the radio buttons with an edit text box, but I'm guessing you probably really only want a handful of possible alternatives:
style="font-size: 9pt; font-family: "Courier New"; color: black;">
style="font-size: 9pt; font-family: "Courier New"; color: black;">DataFile
style="font-size: 9pt; font-family: "Courier New"; color: navy;">=
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">PickFile
style="font-size: 9pt; font-family: "Courier New"; color: black;">(
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"Select
Data File:"
style="font-size: 9pt; font-family: "Courier New"; color: navy;">,,
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"JMP
Files|JMP"
style="font-size: 9pt; font-family: "Courier New"; color: black;">})
style="font-size: 9pt; font-family: "Courier New"; color: navy;">;
style="font-size: 9pt; font-family: "Courier New"; color: black;">dt1
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Open
style="font-size: 9pt; font-family: "Courier New"; color: black;">DataFile)
dt1
style="font-size: 9pt; font-family: "Courier New"; color: navy;"><<
minimize window
style="font-size: 9pt; font-family: "Courier New"; color: black;">DataName
dt1
get name
style="font-size: 9pt; font-family: "Courier New"; color: black;">VarList
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">ColumnDialog
style="font-size: 9pt; font-family: "Courier New"; color: black;">Title(DataName
style="font-size: 9pt; font-family: "Courier New"; color: navy;">||
Bivariate Analysis"
style="font-size: 9pt; font-family: "Courier New"; color: black;">)
style="">
Xvar
ColList(
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"X
Variable"
Min Col(
style="font-size: 9pt; font-family: "Courier New"; color: teal;">1
Max Col(
DataType(Numeric))
style="">
Yvar
ColList(
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"Y
Variable"
Min Col(
Max Col(
DataType(Numeric))
style="">
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">TextBox
style="">
Select
Alpha Level:"
style="">
style="">
AlphaChoice(
style="">
radiobuttons(
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"Alpha
= 0.05"
= 0.01"
= 0.005"
0.001"
style="">
style="">
style="">
style="font-size: 9pt; font-family: "Courier New"; color: green;">//
show(VarList);
style="font-size: 9pt; font-family: "Courier New"; color: black;">Proceed
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">char
style="font-size: 9pt; font-family: "Courier New"; color: black;">VarList[
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">nItems
style="font-size: 9pt; font-family: "Courier New"; color: black;">VarList)])
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">if
style="font-size: 9pt; font-family: "Courier New"; color: navy;">==
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"Button(1)"
style="">
If
"OK" was pressed then carry on;
style="">
style="">
xCol
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Char
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"Xvar"
style="font-size: 9pt; font-family: "Courier New"; color: black;">][
style="font-size: 9pt; font-family: "Courier New"; color: black;">]))
style="">
yCol
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"Yvar"
style="">
This bit
extracts which radio button was selected earlier - it's a bit messy,
but it
works;
style="">
style="">
AlphaLevel
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">parse
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">substr
style="font-size: 9pt; font-family: "Courier New"; color: teal;">6
style="font-size: 9pt; font-family: "Courier New"; color: teal;">13
style="font-size: 9pt; font-family: "Courier New"; color: black;">))
style="">
show(AlphaLevel);
style="">
AlphaValue
style="font-size: 9pt; font-family: "Courier New"; color: teal;">0.05
style="font-size: 9pt; font-family: "Courier New"; color: teal;">0.01
style="font-size: 9pt; font-family: "Courier New"; color: teal;">0.005
style="font-size: 9pt; font-family: "Courier New"; color: teal;">0.001
style="font-size: 9pt; font-family: "Courier New"; color: black;">}[
style="font-size: 9pt; font-family: "Courier New"; color: black;">AlphaLevel]
style="">
show(AlphaValue);
style="">
style="">
And finally
run the actual analysis;
style="">
style="">
biv
Bivariate(
style="">
Y(
yCol )
style="">
X(
xCol )
style="">
Fit
Line(
style="">
{Confid
Curves Fit(
Line Color(
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"Green"
style="">
{Set
α Level(
AlphaValue )}
style="">
style="">
style="">
style="">
Otherwise
close down the original table and quit;
style="">
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">close
nosave)
style="">
style="">
style="font-size: 9pt; line-height: 115%;">
clark_woo-seag_
Jun 23, 2011
David,
I want to gain alphalevel as variable.
for example;
biv=Bivariate(
Y( :X1 ),
X( :Y1 ),
Fit Line(
User change Alpha Level in JMP.
I receive alpha level as variable AA.
biv=Bivariate(
Y( :X1 ),
X( :Y1 ),
Fit Line(
{Set α Level(AA )}
Best Regards,
The following script will return the analysis you need, with AA being set to whatever value you specify:
style="">
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"$SAMPLE_DATA/Big
Class.jmp"
style="font-size: 9pt; font-family: "Courier New"; color: black;">AA
style="font-size: 9pt; font-family: "Courier New"; color: teal;">0.1
style="font-size: 9pt; font-family: "Courier New"; color: black;">biv
Bivariate(
style="">
Y(
style="font-size: 9pt; font-family: "Courier New"; color: navy;">:
style="font-size: 9pt; font-family: "Courier New"; color: black;">Height
style="">
X(
style="font-size: 9pt; font-family: "Courier New"; color: black;">Weight
style="">
Fit
Line(
{Confid
Curves Fit(
Line Color(
{Set
α
Level(
AA )}
style="">
style="">
The earlier script will prompt you for a value and then run the analysis, whereas the one above will simply accept whatever value you give AA. Is there anything else you need?
mpb
Jun 23, 2011
I may be wrong but I think that Clark wants to detect what value for alpha the user has chosen to set while viewing the Bivariate report and to capture that value for future use.
Ah... well if so, then the way I'd set about looking for it would be to display the tree structure of the resulting report, and then inspect the tables of numbers that are incorporated into it. The following does that for three such tables:
Class.jmp"
style="">
style="font-size: 9pt; font-family: "Courier New"; color: teal;">0.123
style="">
Bivariate(
style="">
Y(
style="">
X(
style="">
Fit Line(
{Confid
Curves
Fit(
Line Color(
{Set
α
Level(
AA )}
style="">
style="font-size: 9pt; font-family: "Courier New"; color: black;">bivr
biv
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">report
show tree
structure
style="font-size: 9pt; font-family: "Courier New"; color: black;">bivr[
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">NumberColBox
style="font-size: 9pt; font-family: "Courier New"; color: black;">)]
style="">
make combined data table
style="font-size: 9pt; font-family: "Courier New"; color: teal;">2
style="">
make combined
data table
style="">
Unfortunately however I can't actually see anything in any of them that has obviously been derived from the figure of 0.123 that I've fed into the analysis. Has anybody else got any ideas?
mpb
Jun 23, 2011
The only thing I could find (with limited looking) that contains the alpha value is the script that you can save, for example, to the script window. It ought to be possible to get the script as a text string and search for the "Set Alpha Level" piece but I haven't had a chance to try that.
Alternatively you could do something like this...
style="">
Class.jmp"
style="">
style="">
Bivariate(
style="">
Y(
style="">
X(
style="">
Fit Line(
{Confid
Curves
Fit(
Line Color(
{Set
α
Level(
AA )}
style="">
style="">
style="font-size: 9pt; font-family: "Courier New"; color: black;">ss
get script)
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">show
style="font-size: 9pt; font-family: "Courier New"; color: black;">ss)
style="font-size: 9pt; font-family: "Courier New"; color: black;">Start
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">munger
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"α
Level("
style="font-size: 9pt; font-family: "Courier New"; color: navy;">+
style="font-size: 9pt; font-family: "Courier New"; color: teal;">8
style="font-size: 9pt; font-family: "Courier New"; color: black;">Finish
Start
style="font-size: 9pt; font-family: "Courier New"; color: purple;">")"
Start
Finish
style="font-size: 9pt; font-family: "Courier New"; color: navy;">-
style="font-size: 9pt; font-family: "Courier New"; color: black;">Start))
mpb - snap!
Message was edited by: David Q/R
Same approach as Dave ... just slightly different syntax coz I have become very fond of pattern matching ....
biv = Bivariate(
Y( :height ),
X( :weight ),
Fit Line(
{Confid Curves Fit( 1 ), Line Color( {213, 72, 87} )},
ss = Char( biv << Get Script );
pattern = "Set α Level(" + PatArb() >> alpha + ")";
p=PatMatch(ss,pattern);
If (!p,
// alpha not defined, assume default of 0.05
alpha = 0.05
show(alpha)
[ if you see "& # 945;" displayed it should be an α - unfortunately the editor doesn't like displaying the character in quotes - come on SAS - give us a JSL friendly editor for the forums! ]
Message was edited by: _Stig_
