lala
Level IX
How does JSL implement a click-to-get variable value in such a graph?
Follow the script below.
p1 = dt << Graph Builder(
	Variables( X( :weight ), Y( :height ), Group X( :age ), Color( :sex ) ),
	Elements( Bar( X, Y, Legend( 5 ), Response Axis( "X" ), Summary Statistic( "Sum" ) ) )
How to write JSL How to achieve in the graph by clicking on a certain age bar, get this age value?And use this value to perform subsequent operations.
Thanks!
19 REPLIES 19
lala
Level IX
回复: How does JSL implement a click-to-get variable value in such a graph?
OK
Thank Craige!
You taught me how to solve problems so that I didn't just copy code.
Thanks Experts!
hogi
Level XIII
For those who are too lazy to click - or too lazy to use Expression Handling: use the Picture part of the Hover label.
The reaction is immediate (much faster than the time it takes till the hover label appears).
(view in My Videos)
dt = Open( "$SAMPLE_DATA/Big Class.jmp", invisible );
gb = dt << Graph Builder(
	Show Control Panel( 0 ),
fbs = Report( gb ) << XPath( "//FrameBox" );
For Each( {fb}, fbs,
	fb << Set Graphlet( Picture( Caption( Char( myAge = :age[local:_firstRow] ) ) ) )
lala
Level IX
I can only click.
Because some columns have small graphics (other columns have large data), it is difficult to point to hover.
hogi
Level XIII
and if you are too lazy to hit the bars -  just
  1. add a HeatMap plot
  2. with disabled x and y variables
  3. and transparency set to 0:
(view in My Videos)
View more...
	Elements(
		Bar(
			X,
			Y,
		Heatmap( Legend( 6 ) )
		Dispatch( {"Heatmap"}, "", OutlineBox, {Close( 0 )} ),
		Dispatch( {}, "400", ScaleBox,
			{Legend Model(
				6,
				Base( 0, 0, 0, Item ID( "F", 1 ) ),
				Base( 1, 0, 0, Item ID( "M", 1 ) ),
				Properties( 0, {Transparency( 0 )}, Item ID( "F", 1 ) ),
				Properties( 1, {Transparency( 0 )}, Item ID( "M", 1 ) )
lala
Level IX
Still want to trigger scripts by clicking on graphics, not by Hover Labels
But this graphic changes form, and I don't know how to change to write JSL.
I had to go back to the experts.
Thanks!
  • I can only write a script like this, but cannot execute it:
	Size( 632, 1152 ),
	Show Legend( 0 ),
	Variables( X( :weight ), Y( :height ) ),
	Elements(
		Bar( X, Y, Legend( 5 ), Bar Style( "Stacked" ), Response Axis( "X" ), Summary Statistic( "Sum" ) )
gp = Report(p1)["Graph Builder",FrameBox(1)]
Eval(
	Eval Expr(
		gp << Addgraphicsscript(
			Mousetrap(
				a0 = Expr( iFrame );
				dt << Select Where( :height == a0 );
				dt << Select Columns( "height" );
				d3 = dt << Subset( Output Table( "test" ), Selected Rows( 1 ), columns( height ) );
Craige_Hales
Check the log, there is a missing ; and undefined variable iFrame which you don't need because there is only one frame. The original example embedded the frame number into each script. You don't need the eval(evalexpr(...expr(...)...)) because you no longer have the iFrame to embed in the expr(...)
MouseTrap is the strangest function in all of JMP. When it is called, it does nothing at all. And you don't have to place it where it will be called, but you DO have to place it in the body of the script, not in a user function outside of the script. MouseTrap is a way to supply a snippet of JSL that will run when the mouse moves.  When the mouse moves over the framebox, JMP looks for handler functions in the attached graphic scripts and calls them until one handles the mouse.
Craige
lala
Level IX
Thank Craige!
Yes, one of my code changes was deleted by mistake;
Since my actual generated graph bar graph is very small, using Hover Labels is prone to errors and raises unwanted data.So I still need to trigger the script by clicking on the bar chart.
I want to modify it by imitating the script given by the expert earlier in this post.But I studied for a long time, still do not know how to modify.You can only post again to ask the experts for help.
Thanks Experts!
lala
Level IX
Interesting example.
lala
Level IX
frame = (gp << report)[FrameBox( 1 )];
frame << Set Graphlet(
	Picture(
		Try( Close( d3, nosave ) );
		Current Data Table( dt );
		d3 = dt << Subset(
			Output Table( "tt" ),
			Selected Rows( 0 ),
			Rows( dt << Get Selected Rows() ),
			Selected columns only( 0 )
	Reapply( 1 )
This allows mouse clicks and Hover Labels to be used simultaneously.
Click can implement the selected line, Hover Labels can extract a subset of the selected line.
Thanks!
lala
Level IX
