tsolomon
open excel multiple worksheets column name row 2
I am able to open multiple files and specify no header with "Table Contains Column Headers (0)". However, this does not seem to work when trying to open an excel file with multiple worksheets. I tried placing the comment in several locations to no avail. Any ideas?
raw_dt1 = Open(
"C:\Users\ts\Desktop\bacteria testing\Bacteria.xlsx",
Worksheets( {"Test Supply", Table Contains Column Headers( 0 )}));
Thanks
TS
6 REPLIES 6
Re: open excel multiple worksheets column name row 2
Here is some code generated by the JMP Excel Wizard, which opens an Excel workbook with multiple spreadsheets and no headers:
Open(
"C:\Users\txjim\Documents\sample.xlsx",
Worksheets( "Sheet2" ),
Use for all sheets( 1 ),
Concatenate Worksheets( 0 ),
Create Concatenation Column( 0 ),
1,
Has Column Headers( 0 ),
Number of Rows in Headers( 1 ),
Headers Start on Row( 1 ),
Data Starts on Row( 1 ),
Data Starts on Column( 1 ),
Data Ends on Row( 0 ),
Data Ends on Column( 0 ),
Replicated Spanned Rows( 1 ),
Suppress Hidden Rows( 1 ),
Suppress Hidden Columns( 1 ),
Suppress Empty Columns( 1 ),
Treat as Hierarchy( 0 )
tsolomon
Hi Jim, thanks for the email. I tried this and it still does not work for
me. The first row is still selected as the column names.
tsolomon
Hi Jim, while that code didnt work. I did not know about the excel import
wizard, once I used that and outputted the code, I was able to get it to
work with this code.
Open(
"C:\Users\tsolomo1\Desktop\bacteria testing\testing.xlsx",
Worksheets( "Sheet1" ),
Worksheet Settings(
1,
Headers Start on Row( 2 ),
Data Starts on Row( 2 ),
Thanks for your help
TS
ms
Super User ms
Yes, the custom Excel worksheet settings must be enclosed by the the Excel Settings( ) command. The scripting index is potentially misleading here (JMP 12) as it in Example 3 for the Open() command gives the (commented out) option as Excel Options( ) that does not seem to work (JMP 12 for Mac); the first row is included as default.
what version of JMP are you using?
tsolomon
I have JMP Pro 11.1.1
