BookmarkSubscribeRSS Feed
jeff3928
Jun 29, 2012
how to suppress output from Make into Data Table command
I'm using the "<<Make into Data Table" message to extract details from a OneWay report launched from JSL. I then convert the table to a matrx with "<<GetAsMatrix" and close the data table. The problem is I still see a lot of flickering when I run this script. Is there any way to suppress or hide data tables created in this manner? The "Make into Matrix" command is unavailable for this particular dataset.
pmroz
Jun 23, 2011
Solution
Re: how to suppress output from Make into Data Table command
I have the same problem.  Unfortunately Make into data table doesn't support invisible tables directly.  The best I've been able to do is:
  • Run your analysis (i.e. oneway report), with the invisible keyword if that's supported.
  • << Make into data table
  • Set the table to invisible with dt << show window(0)
pmroz
Jun 23, 2011
Solution
