Armando
histogram visual configuration
Can I configure histograms such that every time I create one it shows the counts axis and count axis? I am trying to avoid having to do it manually each time.
Jeff_Perkinson
Re: histogram visual configuration
Sure. Check out the Platforms section of Preferences (File->Preferences on Windows, JMP->Preferences on the Mac).
In the Distribution platform section you can turn on Count Axis and other preferences.
-Jeff
I will add to Jeff's response with a strong suggestion that you take the time to read the "Discovering JMP" document in the JMP Documentation Library. It really provides a big leg up in learning how to get the most out of JMP.
Help==>JMP Documentation Library
