Alma1
graph builder x-axis legend
I am trying to look at the distribution of fat on monthly and seasonal bases. Placing fat values on Y-Axis and month's on X-Axis. The graph Legend for X-Axis starts from Jan,... but I want it to start from Dec.... I tried changing the X-Axis setting by clicking on X variables and typing in the order as I wish but again it mixes up and it is not in the order I want. Any comments?
Plus the label orientation for XAxis cuts the labling in X-Axis. Why is that?
Many thanks
Re: graph builder x-axis legend
You need to set the Value Ordering column property for the Month column.  Go to the data table window and right click on the header(Name) of the column Month.  Then select
     Column Properties==>Value Ordering
There you will be able to set the order of the values for the column Month, to whatever order you want them
Alma1
Got it Thanks so much
