News
On June 1, we’re asking you to select a content label when starting a new topic in the Discussions area. Read more to find out why.
Trung
data show misalign when export to PDF report
Dear Admin,
Please help to advise with below concern,
When I run script to export the variability chart to PDF file with set up page as below:
obj << Set page setup(
                    margins( 0.2, 0.2, 0.2, 0.2 ),
                    scale( 0.78 ),
                    portrait( 0 ),
                    paper size( "A4" )
But the report is mis-alignment in “lot_id” and “source _lot”; they are shifted one column. Please help advise how to solve this
Thanks,
Regards,
Trung-ON Semi
DaveB
Re: data show misalign when export to PDF report
I think this was a bug in 12.0 that was fixed in 12.1 and 13.0.
Please take this issue directly to JMP, at:
     support@jmp.com
DaveB
Can you post either the journal or datatable and jsl?  I did not see the problem in the tests that I ran.  What jmp version and os are you running?
DaveB
Trung
thank you for your advise
