Françoise
customize the color of selected lines
hi,
when I select  a line in a datatabe, I have this color:
How to customize this: to change the blue color of the line selected?
I don't find it in the prefernces.
best regards
Re: customize the color of selected lines
The color for highlight background/text color is used across JMP, including data tables, list boxes, and many other places.  On Windows this color comes from the system settings, and could be controlled on older Windows OS's from the Window Color and Appearance dialog.  On Windows 10 I don't think this dialog is available, but links such as this one detail the registry settings and have links to other tools that will edit the colors.  Note that changing these settings will have an effect on not only JMP, but any app that uses these system settings.
Françoise
thanks for your answer.
best regards
