Our World Statistics Day conversations have been a great reminder of how much statistics can inform our lives. Do you have an example of how statistics has made a difference in your life? Share your story with the Community!
rs
rs
Why is the prediction interval (individual) getting larger with larger sample size?
Hi All,
I am using JMP14 to calculate the prediction  interval of individuals.  On the figure below you will see:
n=1             PI  (     74.5  - 125.5)
n=10           PI  (  63.5     -    136.5)
n=100,000   PI  (34.6       -        165.4)
Should the PI (individual) interval get narrower  as the PI (mean)?
Thx
phil_kay
Re: Why is the prediction interval (individual) getting larger with larger sample size?
I think this is a misunderstanding about prediction intervals. The intervals get wider with higher N because these are intervals within which you expect to find all N observations. I found this white paper really useful in understanding the differences between confidence, prediction and tolerance intervals.
Hope that helps.
Phil
phil_kay
Hope that helps.
Phil
rs
rs
Thank you Phil!
Article Labels
