BookmarkSubscribe
bluenose
Community Trekker
Why is the Mahalanobis Distance calculated in JMP missing?
I have a big dataset containing 94 variables. I ran the multivariate platform on JMP 9, and calculated the correlations. A lot of the variables are correlated.
My next step was to seek for outliers using the Mahalanobis distance. I ran the function, but out of approximately 70 subjects (rows), only 8 had a disance being calculted. All the rest were missing values. My dataset contains missing values, buy minority in compare to the data available. Why did I get only 8 distances and over 60 missing values ? Can't JMP handle missing values or there is another reason ?
Thank you in advance
bluenose
Community Trekker
I figured that one out already, if there are missing values in a row, it doesn't calculate the MD.
I took a few columns out, and now got more reasonable results. What I don't understand is, how both MD and T^2 give the same outliers, but jacknife gives different outliers...
You should be able to track when this is fixed in future JMP releases on the JMP support site:
http://www.jmp.com/support/notes/45/845.html
Thanks,
Michael
Michael Crotty
Sr Statistical Writer
JMP Development
bluenose
Community Trekker
Thanks for using JMP software!  We are aware of the issue of the jackknife giving different outliers than both MD and T^2, and we are working to correct that for future releases of JMP.
Thanks,
Michael
Michael Crotty
JMP Development
Thanks,
Michael
Michael Crotty
JMP Development
bluenose
Community Trekker
Thank you Michael, I will rely on the MD's for now.
