manja
Variable to a JMP plot
    I am new to JSL and need some help.. I want to get a script for variability plot but i want to pass a value that would control whether i need the variability summary report or not.. I tried the following as shown below but it seems to print variability summary report all time..
In the code below, if control is set to 1 i want the varibility summary report. If set to 0 i want to disable variability summary report...
If i hardcode it to Variability Summary Report(1) or Variability Summary Report(0) it works
control = 0;
New Window( "Variability Chart of RRAW_BER",
	V List Box(
		Variability Chart(
			Y( :RRAW_BER ),
			X( :SERIAL_NUM, :HD_PHYS_PSN, :DATA_ZONE ),
			Connect Cell Means( 1 ),
			Std Dev Chart( 0 ),
			Points Jittered( 1 ),
			Variability Summary Report( control ),
				Dispatch(
					{"Variability Chart for RRAW_BER"},
					"Variability Chart",
					FrameBox,
					{Row Legend(
						:SPC_ID_x,
						Color( 1 ),
						Color Theme( "JMP Default" ),
						Marker( 0 ),
						Marker Theme( "" ),
						Continuous Scale( 0 ),
						Reverse Scale( 0 ),
						Excluded Rows( 0 )
cwillden
Re: Variable to a JMP plot
That is somewhat surprising, but here's an easy work around.  Just swap in this line:
parse(eval insert("Variability Summary Report( ^control^ )"))
Bit of a hack, but that should work for you.  It evaluates the value of "control" in a string and then parses the string into an expression for evaluation.
A cleaner solution would be to name the variability chart object and then send the message to add the variability chart or not after the variability report already exists.  Here's an example with 2 Factors Crossed sample data:
dt = Current Data Table();
control = 1;
varchart = dt << Variability Chart(
	Y( :Measurement ),
	X( :Operator, :part# ),
	Standard( :Standard )
if(control, varchart << Variability Summary Report( 1 ))
-- Cameron Willden
cwillden
control = 1;
	Y( :Measurement ),
-- Cameron Willden
manja
Thanks a lot @cwillden appreciate it.. I liked the easy workaround as it fits my script well, but it doesnt seem to be working (i cant get teh variability summary at all).. However the cleaner solution you provided works..
