BookmarkSubscribeRSS Feed
summer7
Jun 23, 2011
Tree Map Link
Is there anyway you can create links to outside urls in a tree map in JMP? Something similart to how the tree map works in the smart money map of the market tree map.
http://www.smartmoney.com/map-of-the-market/
Thanks!
Re: Tree Map Link
There are two applications on the JMP File Exchange that between them contain examples of probably all the functionality you'd need to do what you require:
(a) "Internet Traffic with Tree Maps" in the "Internet" section, which contains scripts for tree mapping and data filtering.
(b) "Google Finance JMP Script" in the "Finance" section, which pulls historical stock data off the internet from Google Finance based on a ticker and date range.
I'll guess you might need to incorporate an "update" button if the data you're downloading is changing rapidly, but that would be easy enough to do. You can get straight to the File Exchange from here: http://www.sas.com/apps/demosdownloads/jmpFileExchange_PROD__sysdep.jsp?packageID=000416&jmpflag=Y
summer7
Jun 23, 2011
Re: Tree Map Link
I just wanted to say thank you for your help. We are testing this out to see how this works for us.
Thank you again.
j
Re: Tree Map Link
You're welcome - good luck with it, and if you run into difficulties just post on this thread again; somebody around here will probably be able to help out!
David
