new_2_JMP
Split a long column begins with a keyword and ends 1 row before another keyword is reached
Split a long column begins with a keyword and ends 1 row before another keyword is reached. Please see attached example Excel file for the data table before and after the split
Number of test per frequency is not always the same from as high as test20 to as low as test 13
Number of frequency test is not in an increment of 100 but they can be place in a list. In our example,
the frequency list is (100, 200, 300, 400, 500, 550, 650)
Thanks
new_2-JMP
Re: Split a long column begins with a keyword and ends 1 row before another keyword is reached
Just create a new column that increments by 1, every time the Original column has Freq in it's value.  Then split on the new column.
Here is a simple script that does it
names default to here(1);
dt=current data table();
dt<<new column("split");
for each row(if(row()==1,hold=0);
	if(left(:Original,4) == "Freq", hold++);
	:split=hold
dt << Split(
	Split By( :split ),
	Split( :Original ),
	Sort by Column Property
	:split=hold
dt << Split(
	Split By( :split ),
	Split( :Original ),
new_2_JMP
Hi txnelson,
Thanks a lot for your helps, it works but can you help explain to me the meaning the of below codes:
if(row()==1,hold=0)
    row()==1:  are you checking for non empty row?
    hold = 0: what does this do?
   left(:Original,4): I do not understand the meaning of left, : Original and 4
Thanks
Dat N
