uday_guntupalli
Level VIII
Sort a matrix
All,
     Is there a way to achieve functionality similar to what is shown below :
A = [10 -12 4 8; 6 -9 8 0; 2 3 11 -2; 1 1 9 3]
    Upon sorting, how can i retain the original positions of the elements ?
    For e.g. if i wanted to sort each column of the matrix, I can only think of doing the following:
for(i = 1, i <= N cols(A), i ++,
          t = A[0,i];
          t1 = sort descending(t);
    Now, how can I determine the original position of the elements and retain them ?
    https://www.mathworks.com/help/matlab/ref/sort.html - In Matlab, there is a second argument to the sort function which returns the index
     Similarly in R, you can retain the index. Wondering what is the best way to do that in JMP ?
Best
Uday
Re: Sort a matrix
This adaption should work:
A = [10 -12 4 8; 6 -9 8 0; 2 3 11 -2; 1 1 9 3];
sort matrix = Function( { m }, { t, b=[], i=[] },
For( j = 1, j <= N Cols( m ), j++,
t = A[0,j];
b ||= Sort Descending( t );
i ||= Matrix( Reverse( As List( Rank Index( t ) ) ) );
Eval List( { b, i } );
{ B, I } = sort matrix( A );
Show( A, B, I );
Re: Sort a matrix
Take a look at "Ranking and Sorting" in the "Data Structures, Matrices" section of the Scripting Guide
uday_guntupalli
Level VIII
Re: Sort a matrix
@txnelson
         I believe you are referring to the content that is also covered here - https://www.jmp.com/support/help/14/ranking-and-sorting.shtml . However, this does not expand on capturing the indices that I am looking for while performing the sort. Hopefully, I am not missing something.
Best
Uday
Re: Sort a matrix
Um, it is the ranking bit...
uday_guntupalli
Level VIII
Re: Sort a matrix
@Mark_Bailey & @txnelson
    I understand that it looks obvious to you that Rank() does what I want, however , here is an example of why I am asking for:
In Matlab, here is what happen when you try to sort a matrix. Apologies for pulling this example from a different platform, I tried to avoid doing that but I can't think of a better way to explain what I am after. So if you look at the values of  "I", it retains the indices
Now, if I wanted to do the exact samething in JMP , is this the way you are recommending me to take, it yes, it doesn't get me the same result. Also, I would appreciate not having to use a loop for something like this
for(i = 1 , i <= N Cols(A), i++,
		t = A[0,i];
		t1 = Sort Descending(t);
		ranks = Rank(t);
Best
Uday
Re: Sort a matrix
t = A[0,j];
Show( A, B, I );
uday_guntupalli
Level VIII
Re: Sort a matrix
@Mark_Bailey
    Thank you. I will submit a request to the wish list to provide a canned function for this.  I hope in the future, JMP will come up with a way to not have to loop through the matrix. I would love to see the apply() function family from R introduced into JMP.
Best
Uday
