shaira
How to remove Points or Smooth Legend for Graph Builder using JSL?
By default if there are points and smoothing line in Graph Builder, there are legends for both. Sometimes, having two legends is redundant and I would like to get rid of one. What is the syntax for this?
I made a graph builder function (see below). But I can't seem to remove the Legend even if I put Legend (0) in Points.
//Variable //Definition
 //listin ==> list object which contains the following arguments:
 //1. Ncol for Line Up Box output
 //2. Frame size length
 //3. Frame size height
 //4. X axis column
// 5+. Y axis columns
// grp ==> grouping variable for X
//ovl ==> grouping variable for overlay (fitting)
// plotout ==> line up box object output
dgbplot = Function({listin,grp,ovl},{plotout},
                  plotout=Lineup Box(N Col(listin[1]),);
                  For (i=5, i<=Nitems(listin), i++,
                       gb = Graph Builder(
                                          Size( Eval(listin[2]), Eval(listin[3]) ),
                                          Show Control Panel( 0 ),
                                          Variables(
                                                     X( Column(Eval(listin[4]))),
                                                     Y( Column(Eval(listin[i]))),
                                                     Group X(Column(grp)),
                                                     Overlay(Column(ovl))
                                          Elements( Points( X, Y ), Smoother( X, Y, Legend(0), Lambda(5))),
                        gbr = gb << report;
                    plotout;
On the other hand, I tried making some "trial" script and it does what I want. I can't understand why.
Graph Builder(
	Size( 960, 300 ),
	Variables(
		X( :weight ),
		Y( :height ),
		Group X( :sex ),
		Overlay( :sex )
	Elements(
		Points( X, Y, ),
		Smoother( X, Y, Lambda( 5 ) )
Thanks,
Shaira
Re: How to remove Points or Smooth Legend for Graph Builder using JSL?
I believe that your function had an issue with what it was returning.  Your "plotout" element was being defined withing the function as:
This is a completed object, which contains an empty lineup box.  Nothing else in the function adds to it.  However, it is the element that you specify that should be returned from the function.  The script below will generate the plots you want.  Please note the simple change in the function, that incorporates the Graph Builder code inside of the Lineup Box()
dgbplot = Function( {listin, grp, ovl},
	{plotout},
	plotout = Lineup Box( N Col( listin[1] ),
		For( i = 5, i <= N Items( listin ), i++,
			gb = Graph Builder(
				Size( Eval( listin[2] ), Eval( listin[3] ) ),
				Variables(
					X( Column( Eval( listin[4] ) ) ),
					Y( Column( Eval( listin[i] ) ) ),
					Group X( Column( grp ) ),
					Overlay( Column( ovl ) )
				Elements( Points( X, Y ), Smoother( X, Y, Legend( 0 ), Lambda( 5 ) ) )
			// uncomment the lines below to remove smoother legend and keep points
			/*,SendToReport(
				Dispatch(
					"400",
					LegendBox,
					{Legend Position( {2, [0, 1], 1, [-1, -1]} ), Position( {0, 1, -1, -1} )}
			gbr = gb << report;
	plotout;
listin = {1, 960, 300, "weight", "height"};
nw = New Window( "test", vlb = V List Box() );
myplot = dgbplot( listin, "sex", "sex" );
vlb << append( myplot );
