What is the easiest way to set values for cells, where the number of cells is unknown. For example, in the following script, it is possible to set all cells where :age==12 to :age==0, and the number of cells where :age==12 is unknown?
dt = Open( "$SAMPLE_DATA/Big Class.JMP" );
dt << Select Where( :age == 12 );
:age << Set Selected;
Column( "age" ) << Set Values( {0} );
This is one way to do it
:age[dt << Get Selected Rows] = 0;
//Or even simpler
:age[dt << get rows Where( :age == 12 )] = 0;
//Or even simpler
Perfect. Thanks!
