BookmarkSubscribeRSS Feed
DamionSparhawk
Contributor
Jul 13, 2018
Select, Delete, and Color
Okay new project, I still have some unfinished questions on the last one, but they're more aesthetic than priority. Anyway, here's the task; I have a excel sheet that contains a log of all events for a week, I would like to delete all the events that are not pertinent to the task, and then color other rows that contain common known issues or events relating to issues so they're easy to pick out of the lot. Column three contains the event data, column 1 contains the tool data, if possible I'd love to have the remaining data broken down by tool but one step at a time!
I browsed around and found a script that seemed like it might handle part of the process, deleting the known variables, but it isn't working. So... here's what I got.
dt = Open ();
column_list = {"Alarm ID"
For( i = N Items( column_list ), i > 0, i--,
	dt << Select Where( as column(column_list[i]) ="'00000018", "'0000000E", "'000000B9", "'000000C1", "'000000CC", "'000000DF", "'000000E2",
	"'0000023B", "'00000D15", "'00000D16", "'00000D1A", "'00000DEF", "'00000DF0", "'00000DF3", "'00000E6A",
	"'00000E6D", "'00000EB2", "'00000ED6", "'00000F1A" );
	dt << delete rows;
Thanks in advance!
Jun 22, 2012
Solution
Re: Select, Delete, and Color
The syntax of the Where Clause is incorrect.  It should be:
dt = Open ();
	dt << Select Where(
	as column(column_list[i]) == "'00000018" |
	as column(column_list[i]) == "'0000000E" |
	as column(column_list[i]) == "'000000B9" |
	as column(column_list[i]) == "'000000C1" |
	as column(column_list[i]) == "'000000CC" |
	as column(column_list[i]) == "'000000DF" |
	as column(column_list[i]) == "'000000E2" |
	as column(column_list[i]) == "'0000023B" |
	as column(column_list[i]) == "'00000D15" |
	as column(column_list[i]) == "'00000D16" |
	as column(column_list[i]) == "'00000D1A" |
	as column(column_list[i]) == "'00000DEF" |
	as column(column_list[i]) == "'00000DF0" |
	as column(column_list[i]) == "'00000DF3" |
	as column(column_list[i]) == "'00000E6A" |
	as column(column_list[i]) == "'00000E6D" |
	as column(column_list[i]) == "'00000EB2" |
	as column(column_list[i]) == "'00000ED6" |
	as column(column_list[i]) == "'00000F1A" );
	dt << delete rows;
Jun 22, 2012
Solution
dt = Open ();
	dt << Select Where(
	dt << delete rows;
DamionSparhawk
Contributor
Jul 13, 2018
Awesome, yeah that works unsurprisingly, okay so that helps immensely, I'll play around with this and see if I can't figure out the rest, thanks!
DamionSparhawk
Contributor
Jul 13, 2018
Okay, back again, I got some results, however I have a problem that is causing my brain to ache a bit more than my foot.
dt << New Column ( "Row State 1",
	Row State,
	Set Formula ( If( :Alarm ID == "'00000D06", Color State(70))),
this bit works to set the marker color of a specific row containing the ID I want, however when I start multiplying it, it stops being able to set the row state color itself. It does generate the Row State in the side tab, and I can apply the states individually, but obviously I'm trying to reduce the amount of manual input, so does anyone know a more efficient way? I've got a metric ton of values to input but here's the snippet I've put in so far.
dt = Open ();
	dt << Select Where(
	dt << delete rows;
	Row State,
dt << New Column ( "Row State 2",
Row State,
Set Formula ( If( :Alarm ID == "'000000B2", Color State(6))),
dt << New Column ( "Row State 3",
Row State,
Set Formula ( If( :Alarm ID == "'000000BE", Color State(6))),
dt << New Column ( "Row State 4",
Row State,
Set Formula ( If( :Alarm ID == "'0000013C", Color State(6))),
dt << New Column ( "Row State 5",
Row State,
Set Formula ( If( :Alarm ID == "'00000D3B", Color State(73))),
