I have a script I need to add a data filter in before i run it which creates some charts. I have tried select where and exclude functions as well as the data filter script shown below:
Current Data Table() << Data Filter(
Add Filter( columns( :VRchartExcCol ), Where( :VRchartExcCol == 1 ) ),
Mode( Select( 0 ), Include( 1 ) )
I have tried iterations of the above on different columns and datasets and I cannot get the row select to work in the script. It works when running the data filter on its own outside the script and I can copy out the script from there (pasted above) but when the above is inserted and run in script either by itself or in the main script, the only functions which execute are:
Can you select and exclude rows in scripts?
Message was edited by: shaun
