Srishti
Removing duplicates rows
This is not a simple removal of duplicates- I want to remove duplicate rows by their value matched in 2 columns- in 1 column, there are the unique clinic ids, in the other are the year of diagnosis of a disease. i want to apply the condotion that duplicates for a unique clinic id (ie patient) should be removed if the corresponding years of diagnosis are within a year of each other. any provision for such a thing in jmp? eg, a diagnosis in 2015 and 2016 should be considered as one, and the year 2015 should be retained. i have tried the join and summary options without success. any ideas?
Re: Removing duplicates rows
Here is a small script that I believe will find the duplicates.  It assumes the date column has a JMP date value in it.  The names of the columns used in the script, will have to be changed in the script, to match the actual names in your data table.
dt = Current Data Table();
delList = {};
For( i = 1, i <= N Rows( dt ), i++,
	curID = dt:id[i];
	curRows = dt << get rows where( :id == curID );
	minIDdate = Min( :date[curRows] );
	curDateList = As List( :date[curRows] );
	minIDRow = (curRows)[Loc( curDateList, minIDdate )];
	If( i != minIDRow,
		If( :date[i] <= minIDdate + In Years( 1 ),
			Insert Into( delList, i )
// dt << delete rows( delList );
// or
dt << New Column( "Duplicate", character );
dt:Duplicate[delList] = "Duplicate";
Srishti
thank you so much for your reply. i am a beginner at JMP, and am not sure how to run the script. could you tell me where to substitute the table and column names in this script? eg, table name- Preg, Coulmn names- Clinic number, Year.
I appreciate the help!
ms
Super User ms
Here's another variant of the same idea. It will identify duplicates according to your rules. For 2015 and 2016, 2015 will be retained; for 2014, 2015, 2017, 2018, 2015 and 2017 will be retained, but beware that if there are more than two years consecutive years e.g. 2015, 2016, 2017, only 2015 will be retained.
// Example table
dt = New Table("test",
    Add Rows(13),
    New Column("Clinic", "Character", Set Values({"A", "A", "B", "B", "C", "C", "D", "D", "E", "E", "E", "E", "E"})),
    New Column("Year", Set Values([2016, 2017, 2015, 2016, 2015, 2016, 2015, 2018, 2010, 2011, 2016, 2017, 2018]))
// Select multiples based on criteria: same clinic and same or adjacent year
dt << sort(Replace Table, By(:Clinic, :Year));
dt << select where(Col Min(Row(), :Clinic, If(Row() == 1, 0, Dif(:Year)) <= 1) < Row());
// dt << delete rows;
