Shunee
Remove effects from effect summary by scripting
How can I remove certain effects in effect summary when the Pvalues exceed the value I set by scripting?
ian_jmp
Re: Remove effects from effect summary by scripting
In the 'Effects Summary', 'Remove' is just a button box with underline styling. So, alternatively, you can simulate a button press non-interactively:
names default to here(1);
dt = open("$SAMPLE_DATA/big class.jmp");
ft = dt <<
Fit Model(
	Y( :weight ),
	Effects( :age, :sex, :height ),
	Emphasis( "Effect Leverage" ),
	Run(
		:weight << {Summary of Fit( 1 ), Analysis of Variance( 1 ),
		Parameter Estimates( 1 ), Scaled Estimates( 0 ),
		Plot Actual by Predicted( 1 ), Plot Regression( 0 ),
		Plot Residual by Predicted( 1 ), Plot Studentized Residuals( 0 ),
		Plot Effect Leverage( 1 ), Plot Residual by Normal Quantiles( 0 ),
		Box Cox Y Transformation( 0 )}
Wait(3);
// Get the Fit Model report
ftRep = Report(ft);
// Select the rows in the report that have a p value bigger than 0,05
pVals = Matrix(ftRep[NumberColBox(2)] << get);
bigPvals = Loc(pVals > 0.05);
ftRep[TableBox(1)] << setSelectedRows(bigPvals);
// Simulate a button press to remove these terms
ftRep[ButtonBox(1)] << click;
The Effects Summary table is just a standard JMP Table Box().  Therefore, it will honor any  of the messages that the Table Box() object supports.  One of those messages is
     << delete row()
Here is an example taken from the Scripting Index
     Help==>Scripting Index
that illustrate the use of the delete row() message with a Table Box()
New Window( "test",
	tb = Table Box(
		String Col Box( "string col", {"a", "b"} ),
		Number Col Box( "number col", {1, 2} )
tb << delete row( 1 );
Determining how to point to the Table Box() you are interested in is documented in the Scripting Guide's section on Display Trees
     Help==>Books==>Scripting Guide
Shunee
I am not able to delete the rows even I use Table Box. The Log window return "unable to delete row (i)" . Is ther any other way to do it?
Usually effect summary allow us to select certain effect in the table box and click "Remove" button from the left corner to delete certain effect. Can do this by scripting? How can I select the row in table box and activate the "Remove" button to delete the selected row by scripting?
I was able to replicate your findings.....it will not let you delete a row in that particular table.  However, there is a work around.  Take a look at the below script.  It turns out that you can delete the entire table, so what the script does, is to make a copy of the table, which then you can delete the rows you want to delete.  You can then copy the table back into the report and finally delete the old table.
dt=open("$SAMPLE_DATA/big class.jmp");
ft = dt << Fit Model(
	Y( :height ),
	Effects( :age, :sex, :sex * :age ),
	Run(
		:height << {Summary of Fit( 1 ), Analysis of Variance( 1 ),
		Parameter Estimates( 1 ), Lack of Fit( 0 ), Scaled Estimates( 0 ),
ob=vlist box();
ob<<append(report(ft)["Effect Summary"][tablebox(1)]);
ob[tablebox(1)]<<delete row(3);
wait(5);
report(ft)["Effect Summary"]<<prepend(ob[tablebox(1)]);
wait(5);
report(ft)["Effect Summary"][tablebox(2)]<<delete
ian_jmp
ft = dt <<
Fit Model(
	Y( :weight ),
	Run(
Wait(3);
ftRep = Report(ft);
Shunee
Thank you very much!
