Gabriel
Regressions: Comparing groups
Good day,
I have a set of regression for three groups (see attached image1), and I want to see how one group differs from the other. I would normally check how parallel the regression lines are one to another, I just simply compare the regression slopes of one group to another as it is in the image2 attached.
What is the best way to approach this?
Thierry_S
Re: Regressions: Comparing groups
Hi Gabriel,
The beauty of JMP is that you can build relatively complex models to compare the effect of different factors on your outcome. Hence, I would recommend to you look into the Fit Model platform in the Help section.
Specifically, the model would include the NDSI, the Genotype, and the interaction between those two factors: this interaction factor will allow you to compare the "slopes" of your regressions.
I hope it helps.
Best,
TS
Thierry R. Sornasse
Thierry_S
Hi Gabriel,
I hope it helps.
Best,
TS
Thierry R. Sornasse
Article Labels
