ankitgssingh
RUNNING A SCRIPT WITH TROW() IN IT
Hello Community,
Is there any way in JMP to use try to keep the script running if some part of it fails but still give me a log file of the part that did not run?
As if we use throw(), the script would stop as soon as it gets an error. I dont want the script to stop but I also want the error messages stored somewhere so that I can understand what did not work ?
Craige_Hales
Re: RUNNING A SCRIPT WITH TROW() IN IT
write("\!ntry some JSL...");
try(
	write("\!ntry 1...");
	junk("what would this do?");
	write("\!ntry 2...");
, // catch errors here
	write("\!nthis is what went wrong:",exception_msg);
write("\!nDid it work?");
try some JSL...
try 1...
this is what went wrong:{"Name Unresolved: junk"(1, 2, "junk", junk("what would this do?") /*###*/)}
Did it work?
Craige
Craige_Hales
try(
try some JSL...
try 1...
Did it work?
Craige
