Map of Ireland
Hi, SAS JMP version 9 has this really cool feature called Maps. But it doesn't have a map of Ireland? Does anyone have one? I know I can create one but it would be really useful if someone out there already has one!
9 REPLIES 9
Re: Map of Ireland
Rakhi,
I've made the two files you need, and have submitted them to the JMP file exchange. Don't knwo how long that will take to show up. Is there another way I can send them to you?
I got the raw data from http://www.diva-gis.org/gdata.
Message was edited by: Rastignac Eugène de
Re: Map of Ireland
I'm an idiot. Of course there's another way I can get them to you.
You need two files: One for names of administrative units, another for X-Y coordinates. I'll post two replies here: they contain scripts that you can run to recreate these two tables. Save them in the JMP 9 Map folder,
C:\Program Files\SAS\JMP\9\Maps
on Windows.
To test that they work, open the file with "Name" in its title, then Graph Builder. Drag the Name column to the Shape field and you should see a map of Ireland.
IRL-Admin1-Name
New Table( "IRL-Admin1-Name",
Add Rows( 26 ),
New Column( "Shape ID",
Numeric,
Nominal,
Format( "Best", 12 ),
Set Values(
[1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20,
21, 22, 23, 24, 25, 26]
New Column( "Name",
Character,
Nominal,
Set Property( "Map Role", Map Role( Shape Name Definition ) ),
Set Values(
{"Carlow", "Cavan", "Clare", "Cork", "Donegal", "Dublin", "Galway",
"Kerry", "Kildare", "Kilkenny", "Laoighis", "Leitrim", "Limerick",
"Longford", "Louth", "Mayo", "Meath", "Monaghan", "Offaly", "Roscommon",
"Sligo", "Tipperary", "Waterford", "Westmeath", "Wexford", "Wicklow"}
New Column( "Name Variant",
Character,
Nominal,
Set Values(
{"Ceatharlach", "An Cabhán", "An Clár", "Corcaigh",
"Dún na nGall|Tyrconnel", "Baile Átha Cliath", "Gaillimh", "Ciarraí",
"Cill Dara", "Cill Chainnigh", "Laois|Leix|Queens", "Liatroim",
"Luimneach", "An Longfort", "Lú", "Maigh Eo", "An Mhí", "Muineachán",
"Uíbh Fhailí|Kings", "Ros Comáin", "Sligeach", "Tiobraid Árann",
"Port Láirge", "An Iarmhí", "Loch Garman", "Cill Mhantáin"}
New Column( "HASC_1",
Character,
Nominal,
Set Values(
{"IE.CW", "IE.CN", "IE.CE", "IE.CK", "IE.DL", "IE.DN", "IE.GY", "IE.KY",
"IE.KE", "IE.KK", "IE.LS", "IE.LM", "IE.LK", "IE.LD", "IE.LH", "IE.MO",
"IE.MH", "IE.MN", "IE.OY", "IE.RN", "IE.SO", "IE.TY", "IE.WD", "IE.WH",
"IE.WX", "IE.WW"}
New Column( "TYPE_1",
Character,
Nominal,
Set Values(
{"Administrative County", "Administrative County",
"Administrative County", "Traditional County", "Administrative County",
"Administrative County", "Administrative County", "Traditional County",
"Administrative County", "Administrative County"}
New Column( "ENGTYPE_1",
Character,
Nominal,
Set Values(
{"County", "County", "County", "County", "County", "County", "County",
"County", "County", "County", "County", "County"}
New Column( "Shape_Leng",
Numeric,
Continuous,
Format( "Fixed Dec", 20, 11 ),
Set Values(
[2.05258433015, 3.27043638023, 8.35971300498, 19.4433078493,
20.2669642572, 3.71075015147, 19.3924473686, 14.1720450292,
2.62575441163, 2.37490396369, 2.35114471492, 2.76098201597,
4.27809102296, 1.82093001976, 2.82976941685, 19.6470633607,
3.27967920874, 2.42486003528, 3.75601958366, 3.59356133577,
5.78697948406, 4.4318654094, 4.3092790322, 2.62272201705, 4.57136886558,
2.85894316428]
New Column( "Shape_Area",
Numeric,
Continuous,
Set Values(
[0.135840426244, 0.266850986622, 0.442550992666, 1.01574254459,
0.685608637113, 0.120237380902, 0.84650498539, 0.601785118803,
0.24255568815, 0.269430519766, 0.220694910435, 0.21182921374,
0.35710761489, 0.151345614182, 0.116194745876, 0.772273487973,
0.300704048765, 0.180818490125, 0.254905176503, 0.34784311632,
0.259981009714, 0.591944736032, 0.243129623479, 0.256224446036,
0.296526592892, 0.253709871272]
Re: IRL-Admin1-Name
Hi Eugene,
This is fantastic! Thanks a million.
Cheers,
Rakhi
IRL-Admin1-XY
New Table("IRL-Admin1-XY", Add Rows(4305), New Table Variable("SHP Min X", "-10.6630539999999"), New Table Variable("SHP Min Y", "51.4195829999999"), New Table Variable("SHP Max X", "-5.99361099999999"), New Table Variable("SHP Max Y", "55.4504170000001"), New Column("Shape", Numeric, Nominal, Format("Best", 12), Set Values([1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 13, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 14, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 15, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 16, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 18, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 21, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 22, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 23, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 24, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 25, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26, 26])), New Column("Part", Numeric, Nominal, Format("Best", 12), Set Values([1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 3, 3, 3, 3, 3, 3, 3, 3, 4, 4, 4, 4, 4, 4, 5, 5, 5, 5, 5, 5, 5, 5, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 7, 7, 7, 7, 7, 7, 7, 7, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 3, 3, 3, 3, 4, 4, 4, 4, 4, 4, 4, 4, 5, 5, 5, 5, 5, 5, 5, 6, 6, 6, 6, 7, 7, 7, 7, 7, 7, 7, 7, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 4, 4, 4, 4, 4, 4, 4, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 6, 6, 6, 6, 6, 6, 6, 7, 7, 7, 7, 7, 7, 7, 7, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 3, 3, 3, 3, 3, 3, 3, 3, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 2, 3, 3, 3, 4, 4, 4, 4, 4, 5, 5, 5, 5, 5, 5, 5, 5, 6, 6, 6, 6, 6, 6, 6, 7, 7, 7, 7, 7, 7, 7, 7, 8, 8, 8, 8, 8, 8, 8, 8, 9, 9, 9, 9, 9, 9, 9, 9, 10, 10, 10, 10, 10, 10, 10, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 11, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1])), New Column("X", Numeric, Continuous, Format("Best", 12), Set Values([-6.58900999999997, -6.54214699999994, -6.52887099999998, -6.49216099999995, -6.46326099999993, -6.47653999999994, -6.48200699999995, -6.5124679999999, -6.55933199999993, -6.59291499999995, -6.63118599999996, -6.64055799999994, -6.6288429999999, -6.607756, -6.58588599999996, -6.592422, -6.597601, -6.61478499999998, -6.66320799999994, -6.71788199999998, -6.72569299999998, -6.72647399999994, -6.73115999999999, -6.77099299999992, -6.81004299999995, -6.82878899999997, -6.89049199999994, -6.91619899999995, -6.91782799999999, -6.91001799999992, -6.91470399999997, -6.94047799999999, -6.94282099999998, -6.97562499999992, -6.97562499999992, -6.95297499999998, -6.95297499999998, -6.9646919999999, -6.98031099999997, -7.0279559999999, -7.08340999999996, -7.090439, -7.08731399999994, -7.06595599999992, -7.05404999999996, -6.98390899999993, -6.95821199999995, -6.93737899999991, -6.915841, -6.88424299999991, -6.86393599999997, -6.84987599999994, -6.82644599999998, -6.76005699999996, -6.735502, -6.71350799999999, -6.71234099999998, -6.67804899999999, -7.82055699999995, -7.7999999999999, -7.69694599999997, -7.67526699999991, -7.65666899999997, -7.62444499999998, -7.62000000000001, -7.581389, -7.55427499999991, -7.52307999999999, -7.47338299999996, -7.46378099999993, -7.41472099999993, -7.42388999999992, -7.39639, -7.39389, -7.36416999999995, -7.34333399999991, -7.31185199999993, -7.2579439999999, -7.18820899999997, -7.14636899999999, -7.12660799999998, -7.112662, -7.035954, -7.01968299999993, -6.95343499999996, -6.90810799999991, -6.851157, -6.80815399999995, -6.75322399999999, -6.75330199999996, -6.77909999999997, -6.81628999999998, -6.86510499999997, -6.94297599999999, -6.95692199999996, -6.95110999999997, -6.9255409999999, -6.91856899999993, -6.92902799999996, -6.95575999999994, -7.026657, -7.07779599999998, -7.10336399999994, -7.14288099999993, -7.18588399999999, -7.21029099999998, -7.2300489999999, -7.2672399999999, -7.27517399999999, -7.28235100000001, -7.29978399999999, -7.36835600000001, -7.39470799999998, -7.41879799999992, -7.47179699999998, -7.49503999999996, -7.56756400000001, -7.57779299999999, -7.58708999999999, -7.59638799999993, -7.606492, -7.60800999999992, -7.59638799999993, -7.60452499999997, -7.65682699999991, -7.70680099999993, -7.750969, -7.76026299999995, -7.80559299999993, -7.8532449999999, -7.90322199999991, -7.92646699999995, -7.97760399999993, -8.00201099999993, -8.03571699999998, -8.03455499999996, -7.99620099999999, -7.95298199999991, -7.94138999999996, -7.8780549999999, -7.87861199999992, -7.86833299999995, -7.86749799999996, -9.0252789999999, -9.01472199999995, -9.02083499999992, -9.04860999999994, -9.05527699999993, -9.03361099999989, -9.05250099999995, -9.0269449999999, -9.01438899999999, -8.99752099999995, -8.99530799999997, -8.9101159999999, -8.898687, -8.89057099999997, -8.88393399999995, -8.87840199999999, -8.8411539999999, -8.82566499999996, -8.80833199999989, -8.78288399999991, -8.73235999999992, -8.67335299999991, -8.6102919999999, -8.56677399999995, -8.54353799999996, -8.4483909999999, -8.3689379999999, -8.30142299999994, -8.29882499999997, -8.31533699999994, -8.37149299999999, -8.39197299999995, -8.39791699999989, -8.41542499999991, -8.42070799999993, -8.42855599999996, -8.4359859999999, -8.44217999999995, -8.48678999999999, -8.50535099999996, -8.54209799999995, -8.59453399999995, -8.64686699999993, -8.6845439999999, -8.73638899999997, -8.74583399999995, -8.80472199999997, -8.81472099999996, -8.83527599999991, -8.86250099999995, -8.89472299999994, -8.92194499999999, -8.918611, -8.94361099999992, -8.96638799999994, -8.95749999999998, -8.96694399999996, -8.94194499999992, -8.96416599999998, -8.96249999999998, -8.978611, -8.9463889999999, -8.94083199999994, -8.96083399999998, -8.94750099999999, -8.98527799999999, -9.00472299999996, -9.0286109999999, -9.03638999999998, -9.04305599999998, -9.03027899999989, -9.03416499999997, -9.06194299999993, -9.06194599999998, -9.07750099999998, -9.10138799999999, -9.1124989999999, -9.13416699999999, -9.16250099999996, -9.1741659999999, -9.25527799999998, -9.2613879999999, -9.29138799999993, -9.31027799999998, -9.33916599999998, -9.32194499999991, -9.28416599999991, -9.26972299999994, -9.295277, -9.31361199999992, -9.34360999999996, -9.35083299999997, -9.380833, -9.41749999999996, -9.4425, -9.48028099999999, -9.49861199999998, -9.5319439999999, -9.52638999999999, -9.53694499999995, -9.55138799999992, -9.54194499999994, -9.54527699999994, -9.58083399999993, -9.54694599999994, -9.55027799999994, -9.59416699999991, -9.60583399999996, -9.63360999999992, -9.66583399999991, -9.70083299999993, -9.7086119999999, -9.69861099999992, -9.69638899999995, -9.71249999999998, -9.74027799999993, -9.74083399999995, -9.80361099999999, -9.83861099999996, -9.86194499999999, -9.88972099999995, -9.93916899999999, -9.90805399999999, -9.87027799999999, -9.88472299999995, -9.83527699999996, -9.81083299999995, -9.80416699999995, -9.77360999999996, -9.745834, -9.72472299999998, -9.706389, -9.69416599999994, -9.663612, -9.65083299999998, -9.65972199999993, -9.65194299999996, -9.61694499999993, -9.63694399999992, -9.60916599999996, -9.61305399999998, -9.58138799999995, -9.54805599999992, -9.52972199999999, -9.52749999999998, -9.49583399999995, -9.49361199999999, -9.50694499999992, -9.47638799999993, -9.49027699999999, -9.49361199999999, -9.45694499999996, -9.46027699999996, -9.43194499999993, -9.43249899999995, -9.45638899999995, -9.43194499999993, -9.42750099999995, -9.44361199999992, -9.4463899999999, -9.41749999999996, -9.38972199999995, -9.36805599999991, -9.35083299999997, -9.34750099999997, -9.35805499999992, -9.4019449999999, -9.44416799999999, -9.46694599999995, -9.47638799999993, -9.47194399999995, -9.434167, -9.43194499999993, -9.39249999999993, -9.41027699999989, -9.39527799999996, -9.38361099999997, -9.36472199999992, -9.35916499999996, -9.31083399999994, -9.28694400000001, -9.293611, -9.28249999999991, -9.26305699999995, -9.22083299999997, -9.17027699999994, -9.17361, -9.15249999999998, -9.13861099999991, -9.143055, -9.12083399999995, -9.10083199999991, -9.11861199999993, -9.13916699999999, -9.12749999999994, -9.46638999999993, -9.46249899999998, -9.49749999999995, -9.50249999999994, -9.51472099999995, -9.52916599999998, -9.51694499999991, -9.49194299999999, -9.40750099999991, -9.39194399999997, -9.4002789999999, -9.39749999999992, -9.43305499999997, -9.43972099999991, -9.42472199999997, -9.434167, -9.40916699999991, -9.41916599999996, -9.43638899999991, -9.42305599999997, -9.43083299999995, -9.42805699999997, -9.43638899999991, -9.4425, -9.44916599999999, -9.45750099999998, -9.54527699999994, -9.55527799999999, -9.58027799999997, -9.58805699999999, -9.57416499999999, -9.53583299999997, -10.1630549999999, -10.1563889999999, -10.1597229999999, -10.168056, -10.1791659999999, -10.2297219999999, -10.2386109999999, -10.2086109999999, -9.78083299999992, -9.796944, -9.82916599999999, -9.84416799999997, -9.88360999999998, -9.88638899999995, -9.91194499999995, -9.91972299999998, -9.899722, -9.836389, -9.82249999999999, -9.81416699999994, -9.47805699999992, -9.476944, -9.4941649999999, -9.50638799999996, -9.52749999999998, -9.53305399999999, -9.51027699999992, -9.50472199999996, -8.60588599999994, -8.57312099999996, -8.51950199999993, -8.46389999999991, -8.40531699999997, -8.34177099999999, -8.311982, -8.24843799999991, -8.20276199999995, -8.16028799999998, -8.162375, -8.10411599999998, -8.08860199999992, -8.14183299999996, -8.14735999999999, -8.13753299999991, -8.11603099999996, -8.056443, -7.96429799999999, -7.92743999999999, -7.85863699999999, -7.84975099999997, -7.86416599999996, -7.85360900000001, -7.8419449999999, -7.86805499999997, -7.8813899999999, -7.90638999999993, -7.9274989999999, -7.90416699999997, -7.90472399999993, -7.88805600000001, -7.86583199999996, -7.915278, -7.96749999999997, -7.9975, -8.02138999999994, -8.02194399999996, -8.03083299999992, -8.0013889999999, -8.038611, -8.04861, -8.06138899999996, -8.12972199999996, -8.17027699999994, -8.18027799999993, -8.1963889999999, -8.25361099999992, -8.24861099999993, -8.26472199999989, -8.25194499999992, -8.23305599999998, -8.23805599999997, -8.18250000000001, -8.19416699999999, -8.17527699999994, -8.20749999999993, -8.21027799999996, -8.19861099999997, -8.17027699999994, -8.17527699999994, -8.19750099999999, -8.22305499999999, -8.22249899999991, -8.25861199999991, -8.2547239999999, -8.28083299999997, -8.28916599999997, -8.26249999999999, -8.20305599999995, -8.21305599999994, -8.25694599999991, -8.26749999999998, -8.27027899999996, -8.31972199999996, -8.32916699999993, -8.32416699999993, -8.33361099999991, -8.31972199999996, -8.31638999999996, -8.33639, -8.34083399999997, -8.370834, -8.39249999999998, -8.413611, -8.44749999999993, -8.39249999999998, -8.39083399999998, -8.41583299999991, -8.38361099999997, -8.34805599999999, -8.33250099999992, -8.331389, -8.35250099999996, -8.32416699999993, -8.29638799999992, -8.30305499999992, -8.32416699999993, -8.32138799999996, -8.31361199999998, -8.29305599999992, -8.32916699999993, -8.35972099999998, -8.38694499999997, -8.35083199999997, -8.32916699999993, -8.29416599999991, -8.27750099999997, -8.273057, -8.29305599999992, -8.33749999999992, -8.30638899999997, -8.2958349999999, -8.310834, -8.329723, -8.33916599999992, -8.3847209999999, -8.3897209999999, -8.41805599999998, -8.42805599999997, -8.44138899999996, -8.44138899999996, -8.454722, -8.46027699999991, -8.49027899999999, -8.48861099999999, -8.47416799999996, -8.45027799999991, -8.47583399999996, -8.49416700000001, -8.49305499999991, -8.50694399999998, -8.5269439999999, -8.56027799999993, -8.5697229999999, -8.59694500000001, -8.6124999999999, -8.63472199999995, -8.61583399999989, -8.59694500000001, -8.5680549999999, -8.55138999999997, -8.52916599999992, -8.50860999999998, -8.50194399999998, -8.51027899999997, -8.52749999999992, -8.51972099999995, -8.52972199999999, -8.55138999999997, -8.52805599999999, -8.53916699999996, -8.53249999999991, -8.54361099999994, -8.56361299999992, -8.56305399999991, -8.58194399999997, -8.62749899999994, -8.643056, -8.65861199999995, -8.66472199999993, -8.67805499999992, -8.67972099999992, -8.69694399999997, -8.70972299999994, -8.72805699999998, -8.76416699999999, -8.726945, -8.68194499999999, -8.70250099999993, -8.67583299999996, -8.70361099999997, -8.69638799999996, -8.70638899999995, -8.74638799999997, -8.75916699999999, -8.75194399999992, -8.76027699999992, -8.77416599999998, -8.8058319999999, -8.84972199999999, -8.84972199999999, -8.8797219999999, -8.87694399999998, -8.85416799999996, -8.85583199999996, -8.89083299999999, -8.89583299999993, -8.86694499999993, -8.867501, -8.89194499999996, -8.88860999999997, -8.89861099999996, -8.92249899999996, -8.94027799999992, -8.95194499999991, -8.95583399999998, -8.99638899999997, -9.01527799999991, -9.02416699999992, -9.02916699999997, -9.01305599999995, -9.05027899999993, -9.07027799999997, -9.060833, -9.08083299999998, -9.09860999999995, -9.11972199999997, -9.13194499999992, -9.14749999999998, -9.1397209999999, -9.11583299999995, -9.1075009999999, -9.12361199999992, -9.12861299999992, -9.14583599999998, -9.15916699999997, -9.1708339999999, -9.1774999999999, -9.16416699999996, -9.1724999999999, -9.16861099999994, -9.18805699999996, -9.18972299999996, -9.21416699999992, -9.20749999999993, -9.22749999999996, -9.24416700000001, -9.23694399999994, -9.27138899999994, -9.26805699999994, -9.28749999999991, -9.290279, -9.31083399999994, -9.34305599999999, -9.38138899999996, -9.39027799999997, -9.372501, -9.35749899999996, -9.35638899999992, -9.37972299999996, -9.39860999999996, -9.38472099999996, -9.39249999999993, -9.36749999999989, -9.36027799999994, -9.34305599999999, -9.32250099999993, -9.32805499999989, -9.3352779999999, -9.36749999999989, -9.37194499999998, -9.41305599999998, -9.41194299999989, -9.42416599999996, -9.43138899999997, -9.40638899999999, -9.39416599999993, -9.41416499999991, -9.415278, -9.43027699999993, -9.45472299999995, -9.4463899999999, -9.43361099999993, -9.45472299999995, -9.47360999999995, -9.475278, -9.48805499999998, -9.52972199999999, -9.5352759999999, -9.54749899999996, -9.57361199999997, -9.58916699999992, -9.58638799999994, -9.63083399999999, -9.61972299999997, -9.63527799999991, -9.648055, -9.644723, -9.663612, -9.663612, -9.66972299999992, -9.70305499999995, -9.704723, -9.716388, -9.7513889999999, -9.7169439999999, -9.70083299999993, -9.74361199999993, -9.77360999999996, -9.76083299999999, -9.77694499999996, -9.76416799999998, -9.77694499999996, -9.795278, -9.82194399999992, -9.80972099999997, -9.838055, -9.790278, -9.77305399999995, -9.74860999999993, -9.69083199999994, -9.6691669999999, -9.65361099999996, -9.64750099999998, -9.66194399999995, -9.64805699999994, -9.64583499999998, -9.61694499999993, -9.62250099999994, -9.58472199999994, -9.57305499999995, -9.55027799999994, -9.53916699999996, -9.54194499999994, -9.55638799999991, -9.58472199999994, -9.61972299999997, -9.63416599999999, -9.66249999999991, -9.69083199999994, -9.69583199999994, -9.72416699999997, -9.73027899999994, -9.74194399999993, -9.77472199999994, -9.79416599999991, -9.81583399999994, -9.85083199999997, -9.78972099999999, -9.78416699999991, -9.752499, -9.72083499999997, -9.70138899999995, -9.65972199999993, -9.61360999999999, -9.57138899999995, -9.5680549999999, -9.51194499999991, -9.50916699999993, -9.48638899999997, -9.46361099999996, -9.45972299999994, -9.44416799999999, -9.46138899999994, -9.439168, -9.46361099999996, -9.45194399999997, -9.47861, -9.50138799999996, -9.50583499999993, -9.53250099999997, -9.52749999999998, -9.53916699999996, -9.55360999999994, -9.54138899999992, -9.54805599999992, -9.57416499999999, -9.58138799999995, -9.59583299999991, -9.63972199999989, -9.6758329999999, -9.6691669999999, -9.67861099999999, -9.71805599999999, -9.72694499999994, -9.73138899999998, -9.7480569999999, -9.76583399999998, -9.81138899999996, -9.82527799999991, -9.8658329999999, -9.90305599999999, -9.9069439999999, -9.91416699999996, -9.92583399999995, -9.92305499999998, -9.93527799999993, -9.96694499999995, -10.009722, -10.028611, -10.0375, -10.0541669999999, -10.0447229999999, -10.073055, -10.104723, -10.1163899999999, -10.165277, -10.143612, -10.1580549999999, -10.133611, -10.1280549999999, -10.0908339999999, -10.0763889999999, -10.0558329999999, -10.071388, -10.056946, -10.100279, -10.097501, -10.071388, -10.0524989999999, -10.0325, -10.010834, -9.99805499999997, -9.97416699999991, -9.97361100000001, -9.94749899999999, -9.9841659999999, -10.004721, -9.981944, -9.94749899999999, -9.92916599999995, -9.908255, -9.88721799999996, -9.85631599999994, -9.79450299999996, -9.78243099999997, -9.77035799999999, -9.72786299999996, -9.68198899999999, -9.64818699999995, -9.61631599999993, -9.59506999999991, -9.567544, -9.53373799999992, -9.48400299999992, -9.464204, -9.41156999999993, -9.3927369999999, -9.35796899999991, -9.33092699999997, -9.31643800000001, -9.32657799999993, -9.30533199999991, -9.27974, -9.19447699999995, -9.15373299999993, -9.16580599999992, -9.19674299999991, -9.24020099999996, -9.23416599999996, -9.207607, -9.23416599999996, -9.226923, -9.22933699999999, -9.29332099999999, -9.29452699999996, -9.28547399999997, -9.23174999999998, -9.22571499999998, -9.23455999999999, -9.16632999999996, -9.13244399999991, -9.07784899999996, -9.03894199999991, -8.96184799999992, -8.93578399999996, -8.84269699999993, -8.7583009999999, -8.70616999999993, -8.67638399999993, -8.64063799999997, -8.44361199999992, -8.429688, -8.43194499999999, -8.41857999999991, -8.43138899999997, -8.43416899999994, -8.46083299999998, -8.45751899999999, -8.54194499999994, -8.51194499999997, -8.49468899999994, -8.49916500000001, -8.48638899999992, -8.517517, -8.52249899999993, -8.52917499999995, -8.5697229999999, -8.5635989999999, -8.54972399999997, -8.5635989999999, -8.44749999999993, -8.43861099999992, -8.45750099999998, -8.46527699999996, -8.36583399999995, -8.35527899999994, -8.35638399999999, -8.34805599999999, -8.35916699999996, -8.36775999999998, -8.379167, -8.38079899999991, -8.18138799999991, -8.17416799999995, -8.16138799999999, -8.16361099999995, -8.17694599999993, -8.17749099999998, -8.19194499999998, -7.79748599999994, -7.78974299999999, -7.78802499999995, -7.78527899999995, -8.24694499999993, -8.22694300000001, -8.22027699999995, -8.20527799999997, -8.1897229999999, -8.20027699999997, -8.22527700000001, -8.25138899999996, -7.79748599999994, -7.80527799999999, -7.79577599999993, -7.78750099999996, -7.76299999999998, -7.74972199999996, -7.74029499999995, -7.730279, -7.70916699999998, -7.68861099999992, -7.7030539999999, -7.69579999999991, -7.71472099999994, -7.694166, -7.69470099999995, -7.68027899999993, -7.68361099999993, -7.66857999999996, -7.66472099999999, -7.68083299999995, -7.68251499999991, -7.70194399999997, -7.694166, -7.71638899999994, -7.69694599999997, -7.71027699999996, -7.70144499999998, -7.72138999999993, -7.71194499999996, -7.72027799999995, -7.70360999999997, -7.70972299999994, -7.74749999999995, -7.73528999999991, -7.76916699999998, -7.79357899999997, -7.79858400000001, -7.76749899999999, -7.75916699999993, -7.75196699999998, -7.76249899999993, -7.75747799999999, -7.74194499999999, -7.72918699999997, -7.71138899999994, -7.69140599999997, -7.69579999999991, -7.67694399999994, -7.660279, -7.63299599999999, -7.63583299999993, -7.6141659999999, -7.61472199999992, -7.60250099999996, -7.60472299999992, -7.624167, -7.61749999999989, -7.57189899999992, -7.5769039999999, -7.54797299999996, -7.54138799999998, -7.52138899999994, -7.51750099999998, -7.530822, -7.53027799999995, -7.58581599999991, -7.59527799999995, -7.63360699999998, -7.643056, -7.62359699999996, -7.59083399999997, -7.57638900000001, -7.56027799999993, -7.55916799999994, -7.59527799999995, -7.63916799999993, -7.63694299999997, -7.66137799999996, -7.68359299999997, -7.68083299999995, -7.67748899999992, -7.64083399999993, -7.63690199999996, -7.62305399999991, -7.596924, -7.55688399999997, -7.53916599999991, -7.51580699999994, -7.51308799999993, -7.474671, -7.47082599999993, -7.49527699999993, -7.52694299999996, -7.53305599999993, -7.51641799999999, -7.490295, -7.46691999999996, -7.46250099999998, -7.45471299999997, -7.45749999999993, -7.48305599999998, -7.47357299999993, -7.45800799999995, -7.46250099999998, -7.4757699999999, -7.48583199999996, -7.49694499999993, -7.51580699999994, -7.55583299999995, -7.5408349999999, -7.545277, -7.51805499999995, -7.53472199999993, -7.5097219999999, -7.52805499999994, -7.49969399999998, -7.47083299999997, -7.46750099999997, -7.44861199999991, -7.42861199999999, -7.43359399999991, -7.38305699999989, -7.37694399999992, -7.36083299999996, -7.33801199999994, -7.32472199999995, -7.312499, -7.30361099999993, -7.34249999999992, -7.34805599999999, -7.314168, -7.29027799999994, -7.27194399999991, -7.24749799999989, -7.26638799999995, -7.253602, -7.278055, -7.31530699999991, -7.33027899999996, -7.333618, -7.355279, -7.34810899999997, -7.37416599999995, -7.39801, -7.36972199999997, -7.33911000000001, -7.33416699999992, -7.29083399999996, -7.26916599999993, -7.24267599999996, -7.22527700000001, -7.1947229999999, -7.16967699999998, -7.17638899999997, -7.15748600000001, -7.1536119999999, -7.12359499999991, -7.09250099999997, -7.07027699999992, -7.03967299999994, -7.00861099999997, -7.00527899999997, -6.95527899999991, -6.92077699999999, -6.92419399999994, -6.95250099999993, -6.96191399999992, -6.9619449999999, -7.02194399999996, -7.04805599999997, -7.11805499999991, -7.1569439999999, -7.18860999999993, -7.20305499999989, -7.21249999999998, -7.24639999999999, -7.2564099999999, -7.27387299999992, -7.30548199999993, -7.35309099999995, -7.38021899999995, -7.39305999999994, -7.38825499999996, -7.40081399999991, -7.39356399999991, -7.39288399999998, -7.44305699999995, -7.44860899999998, -7.4439099999999, -7.4579829999999, -7.47720099999992, -7.48283999999995, -7.51971399999991, -7.55248999999992, -7.55330999999995, -7.53736299999997, -7.5723549999999, -7.64862199999993, -7.68472299999991, -7.734985, -7.73944699999998, -7.75061099999999, -7.83441199999993, -7.8480229999999, -7.87093299999998, -7.9252929999999, -7.90502899999996, -7.91388799999993, -7.89001399999989, -7.86221999999998, -7.85528499999992, -7.81280599999991, -7.77880799999991, -7.7560299999999, -7.73742599999997, -7.710621, -7.70583299999998, -7.7390739999999, -7.76527699999991, -7.78760599999993, -7.81943599999994, -7.8292449999999, -7.90990899999997, -7.92752400000001, -7.97082499999993, -8.00329599999992, -8.04528699999992, -8.05271899999997, -8.10760499999998, -8.1144149999999, -8.16866099999999, -8.16168199999999, -8.24719299999993, -8.28198899999995, -8.26416599999999, -8.26083399999999, -8.25527699999992, -8.20027699999997, -8.20638799999995, -8.24750099999994, -8.27027899999996, -8.21027799999996, -8.22308199999992, -8.20805599999994, -8.194703, -8.16527699999995, -8.16467299999999, -8.1491079999999, -8.149722, -8.13472299999995, -8.13189599999998, -8.10919199999995, -8.13140899999991, -8.10805399999993, -8.144721, -8.12416599999995, -8.11578299999997, -8.13472299999995, -8.13305699999995, -8.16083199999997, -8.16694499999994, -8.15472399999999, -8.16694499999994, -8.17083299999996, -8.1875, -8.20527799999997, -8.22918599999997, -8.23305599999998, -8.24859699999996, -8.2975009999999, -8.29194399999994, -8.27191099999999, -8.28805599999993, -8.30361099999999, -8.341388, -8.35192899999998, -8.391907, -8.429688, -8.43805499999996, -8.46194499999996, -8.44416799999993, -8.44750899999997, -8.40138799999994, -8.37694499999998, -8.38583299999999, -8.405823, -8.420278, -8.44140499999992, -8.42138799999998, -8.42749999999995, -8.44194299999992, -8.44138899999996, -8.463055, -8.48472299999992, -8.48694499999999, -8.47747699999991, -8.48638899999992, -8.50805599999995, -8.54194499999994, -8.556397, -8.58694399999996, -8.5847169999999, -8.62188799999996, -8.60357699999997, -8.62416699999994, -8.64360999999991, -8.62694499999992, -8.68027699999999, -8.67968699999995, -8.69250499999993, -8.70749899999993, -8.72576899999996, -8.77194399999996, -8.77249999999998, -8.793612, -8.80305599999997, -8.785279, -8.78308199999998, -8.798585, -8.80694499999999, -8.795278, -8.76299999999998, -8.75861099999992, -8.74138999999997, -8.751892, -8.74749799999995, -8.70472299999995, -8.71138899999994, -8.69579999999991, -8.67416699999996, -8.65307499999995, -8.63638799999995, -8.59138799999994, -8.5496829999999, -8.53638799999999, -8.51638899999995, -8.51527899999996, -8.4891669999999, -8.47083399999997, -8.43416699999995, -8.47027499999996, -8.48416599999996, -8.52249899999993, -8.54916699999996, -8.54858399999995, -8.51583299999993, -8.4763789999999, -8.45361199999991, -8.43138899999997, -8.41305499999993, -8.43805499999996, -8.45249999999999, -8.45471099999998, -8.49972199999996, -8.49638899999991, -8.53638799999999, -8.52972199999999, -8.56694499999992, -8.56305399999991, -8.53305599999999, -8.51250099999993, -8.51527899999996, -8.49416700000001, -8.44694399999992, -8.42694399999999, -8.40194399999996, -8.37805399999991, -8.36688199999998, -8.37361199999992, -8.33410599999996, -8.33581499999997, -8.27250099999998, -8.25305499999996, -8.25138899999996, -8.27194499999996, -8.31583399999994, -8.3386119999999, -8.36248799999993, -8.3813889999999, -8.39027699999997, -8.36805599999991, -8.3507689999999, -8.32083199999994, -8.31030299999992, -8.34249999999997, -8.34416599999997, -8.36416499999996, -8.38079899999991, -8.37361199999992, -8.38416699999999, -8.39527799999996, -8.44583399999993, -8.46027699999991, -8.44472099999996, -8.45416599999999, -8.43527899999992, -8.4480559999999, -8.43194499999999, -8.38861099999997, -8.377501, -8.36305799999991, -8.41305499999993, -8.41972199999998, -8.4252919999999, -8.41916599999991, -8.44249899999994, -8.45416599999999, -8.4386449999999, -8.46301399999999, -8.45117099999999, -8.44305499999996, -8.416943, -8.39972199999994, -8.40249999999992, -8.411945, -8.42472199999997, -8.44250399999999, -8.420278, -8.43029699999994, -8.41967799999998, -8.40750099999991, -8.39361199999996, -8.40020799999991, -8.382499, -8.37305599999991, -8.34860999999989, -8.3425299999999, -8.35527899999994, -8.33300699999995, -8.31972199999996, -8.338056, -8.33416699999992, -8.31916599999994, -8.32641599999994, -8.29805499999992, -8.32416699999993, -8.30798199999998, -8.317992, -8.3269039999999, -8.31583399999994, -8.31750499999993, -8.29638599999993, -8.289672, -8.29805499999992, -8.28637599999996, -8.23361199999999, -8.21638899999994, -8.21362399999993, -8.15972199999999, -8.148055, -8.13690099999991, -8.1296989999999, -8.14527699999991, -8.17077799999993, -8.15583399999997, -8.16416699999996, -8.14581299999998, -8.13527899999991, -8.13916699999993, -8.12189099999995, -8.12188599999996, -8.06861199999992, -8.05139099999997, -8.02638799999994, -8.01638999999995, -8.02471999999995, -8.01527799999997, -8.01805599999995, -7.98138499999999, -7.96805599999999, -7.94250499999993, -7.93916599999994, -7.94472199999996, -7.98194499999994, -7.95880499999998, -7.92916699999989, -7.91467199999994, -7.89410499999991, -7.89916, -7.87249899999995, -7.91249999999991, -7.875833, -7.85305599999998, -7.86583199999996, -7.89361499999995, -7.903076, -7.87359499999997, -7.855278, -7.85972199999998, -7.83805699999999, -7.84972299999998, -7.83027799999997, -7.82527699999997, -7.83300799999995, -7.849717, -7.87359499999997, -7.86805499999997, -7.844178, -7.81694499999998, -7.82305499999995, -7.80688499999991, -7.81359899999995, -7.78916699999996, -7.78861099999995, -7.78082299999994, -7.791382, -7.78750099999996, -7.8041659999999, -7.81638899999996, -6.11578399999996, -6.11916700000001, -6.14585499999993, -6.16638799999993, -6.1725009999999, -6.17972299999997, -6.15694299999996, -6.13079899999991, -6.02638999999999, -6.02130099999999, -6.01194499999991, -5.99638999999996, -6.00579799999997, -6.01416699999999, -6.03527899999995, -6.18640099999999, -6.18305499999997, -6.16357299999999, -6.14916699999998, -6.11194399999994, -6.09861100000001, -6.09916699999997, -6.07861199999991, -6.0869439999999, -6.07583299999993, -6.11027799999994, -6.13250599999998, -6.14861999999999, -6.16802899999999, -6.12305499999991, -6.11969099999993, -6.09583299999997, -6.11805399999997, -6.13299599999999, -6.14638899999994, -6.13361199999997, -6.14583299999998, -6.15416699999992, -6.20027899999991, -6.15916799999991, -6.15472099999994, -6.1235969999999, -6.122501, -6.11194399999994, -6.12138899999991, -6.1313899999999, -6.13079899999991, -6.117501, -6.06805499999996, -6.04748599999999, -6.05138999999991, -6.08194399999991, -6.10192999999998, -6.10028199999994, -6.12194499999993, -6.15808099999998, -6.18861199999992, -6.22918699999991, -6.18972199999996, -6.18861199999992, -6.24694399999999, -6.18029799999994, -6.21252499999991, -6.204723, -6.15472099999994, -6.13079899999991, -6.12361099999993, -6.10028199999994, -6.09083199999992, -6.11194399999994, -6.10527799999994, -6.14599399999997, -6.1782849999999, -6.24841399999997, -6.34797099999992, -6.40509099999997, -6.46413199999995, -6.50408999999996, -6.53519599999999, -6.54196699999994, -6.54077299999995, -6.50292999999999, -6.49502999999993, -6.48937999999998, -6.495518, -6.45349099999999, -6.41489599999994, -6.36810299999996, -6.33477699999997, -6.32049599999999, -6.33331199999992, -6.40808099999998, -6.39299999999997, -6.37940999999989, -6.341658, -6.29106999999993, -6.27974499999994, -6.26458699999995, -6.21361199999996, -9.5269439999999, -9.50694499999992, -9.50083399999994, -9.52583399999998, -9.54138899999992, -9.55583199999995, -9.55694399999999, -9.54361099999994, -9.57305499999995, -9.56194499999998, -9.56083200000001, -9.57583399999993, -9.60749999999996, -9.61750099999995, -9.61750099999995, -9.59916699999991, -9.78083299999992, -9.757499, -9.750833, -9.73861199999993, -9.70749899999993, -9.68416799999994, -9.65972199999993, -9.65249899999998, -9.6741669999999, -9.66249999999991, -9.6330559999999, -9.63805599999989, -9.65416499999998, -9.69138799999996, -9.70416699999993, -9.7563889999999, -9.75861099999997, -9.82694399999991, -9.81583399999994, -9.716388, -9.711388, -9.68972199999996, -9.69583199999994, -9.7069459999999, -9.71749999999997, -9.72305699999998, -9.63083399999999, -9.62361099999993, -9.63360999999992, -9.6247229999999, -9.63972199999989, -9.65027699999996, -9.68583399999994, -9.67472099999992, -9.649721, -9.65361099999996, -9.64083199999999, -9.646389, -9.665278, -9.69305399999996, -9.69527899999991, -9.71805599999999, -9.72361099999995, -9.73305499999998, -9.77194399999996, -9.745834, -9.76694399999997, -9.7563889999999, -9.74416599999995, -9.7597209999999, -9.73638999999992, -9.73638999999992, -9.71083399999998, -9.70361099999991, -9.72472299999998, -9.68194599999998, -9.68472199999997, -9.7119439999999, -9.69194399999998, -9.7119439999999, -9.70749899999993, -9.68416799999994, -9.64250099999998, -9.65861199999995, -10.1613889999999, -10.151945, -10.1463879999999, -10.170278, -10.1758339999999, -10.1663869999999, -10.186943, -10.285278, -10.2674989999999, -10.261945, -10.286388, -10.289167, -10.3036119999999, -10.293611, -10.293611, -10.2019439999999, -10.1774999999999, -10.1886139999999, -10.171388, -10.183611, -10.212499, -10.209167, -10.2313879999999, -10.250278, -10.260279, -10.232501, -10.2297219999999, -10.207501, -8.49483499999991, -8.43860699999999, -8.40839399999999, -8.38489599999991, -8.37146799999999, -8.36978799999997, -8.35552300000001, -8.310205, -8.28418799999992, -8.26320699999997, -8.252296, -8.23991799999993, -8.209496, -8.21578899999992, -8.24201499999998, -8.23572199999995, -8.20739699999996, -8.16753299999994, -8.15284599999995, -8.14340599999991, -8.12976799999996, -8.10249299999998, -8.03010799999998, -8.02008399999994, -8.00223399999999, -7.96062599999999, -7.95653299999992, -7.96130799999997, -8.04656799999992, -8.0683949999999, -8.12892899999997, -8.18093899999991, -8.2056629999999, -8.25852499999991, -8.30142299999994, -8.3689379999999, -8.4483909999999, -8.54353799999996, -8.56677399999995, -8.6102919999999, -8.67335299999991, -8.73235999999992, -8.78288399999991, -8.80833199999989, -8.82566499999996, -8.8411539999999, -8.87840199999999, -8.88393399999995, -8.89057099999997, -8.898687, -8.9101159999999, -8.99530799999997, -8.99752099999995, -9.01438899999999, -9.023057, -9.04916599999996, -9.07694499999997, -9.08583299999992, -9.07861099999997, -9.05250099999995, -9.0236109999999, -8.98638999999992, -8.96749999999997, -8.96027799999996, -8.97583299999997, -8.95749999999998, -8.93972199999996, -8.92694599999993, -8.93527799999993, -8.94416699999999, -8.959722, -8.95583399999998, -8.94361099999992, -8.91138999999998, -8.90305599999994, -8.95027899999991, -8.98972199999992, -8.97138899999993, -8.99583199999989, -9.02750099999997, -9.05194499999993, -8.98694399999999, -8.97972299999992, -9.00861199999997, -8.96416599999998, -8.99249999999989, -8.978611, -8.94750099999999, -8.93694399999993, -8.97250099999997, -8.96749999999997, -8.99527599999999, -8.99805499999997, -9.02027799999991, -9.01916599999993, -9.04638799999998, -9.05083499999995, -9.0697219999999, -9.106945, -9.11972199999997, -9.11194499999999, -9.12027799999993, -9.12694399999992, -9.16083299999997, -9.21972099999999, -9.22583399999996, -9.27194499999996, -9.29861099999999, -9.33583399999998, -9.36138999999992, -9.4019449999999, -9.45472299999995, -9.46527699999996, -9.48861099999999, -9.52583399999998, -9.55472199999991, -9.55027799999994, -9.56861099999998, -9.54138899999992, -9.55638799999991, -9.54861199999994, -9.56527899999998, -9.58027799999997, -9.57249899999999, -9.58750099999992, -9.60083399999991, -9.61472299999997, -9.63249999999999, -9.62027699999993, -9.59972099999999, -9.61305399999998, -9.60083399999991, -9.61972299999997, -9.60916599999996, -9.62583299999994, -9.62250099999994, -9.57305499999995, -9.5697209999999, -9.56194199999999, -9.55083399999995, -9.57027699999998, -9.58027799999997, -9.57916599999993, -9.59972099999999, -9.59749899999991, -9.55083399999995, -9.55638799999991, -9.59472099999999, -9.601946, -9.61305399999998, -9.59805499999999, -9.61416599999996, -9.58305599999994, -9.58027799999997, -9.59416699999991, -9.59805499999999, -9.64361099999997, -9.66972299999992, -9.63972199999989, -9.62694599999992, -9.64805699999994, -9.68583399999994, -9.67472099999992, -9.66472199999993, -9.62861199999992, -9.6280559999999, -9.64694499999996, -9.6363879999999, -9.64916699999998, -9.66416599999991, -9.69249999999994, -9.713056, -9.70916499999993, -9.73194299999994, -9.73527699999994, -9.76249899999999, -9.77472199999994, -9.78194499999989, -9.78916499999991, -9.81583399999994, -9.84416799999997, -9.84138899999994, -9.85138799999993, -9.87638799999996, -9.84638999999993, -9.8608329999999, -9.87138999999996, -9.899722, -9.90805399999999, -9.89416699999993, -9.88305699999995, -9.89527699999991, -9.87805599999996, -9.89527699999991, -9.88972099999995, -9.84249899999998, -9.83583299999998, -9.8213899999999, -9.79249999999991, -9.80361099999999, -9.78805499999999, -9.81361099999992, -9.8230559999999, -9.80194399999999, -9.82694399999991, -9.84749999999997, -9.858611, -9.8658329999999, -9.88305699999995, -9.88638899999995, -9.85194399999995, -9.85194399999995, -9.82694399999991, -9.86638899999991, -9.85360999999995, -9.88472299999995, -9.90083399999992, -9.90972299999999, -9.89639, -9.9002779999999, -9.88638899999995, -9.90138999999999, -9.88972099999995, -9.9086099999999, -9.9069439999999, -9.91583299999996, -9.91638899999998, -9.940833, -9.95972199999994, -9.95749999999998, -9.98027999999999, -9.96861099999995, -9.98860999999999, -10.029721, -10.0513889999999, -10.0347219999999, -10.071945, -10.08639, -10.0869439999999, -10.1119429999999, -10.1174999999999, -10.140834, -10.1263889999999, -10.1475, -10.1791659999999, -10.198056, -10.174722, -10.165277, -10.1541669999999, -10.17861, -10.176944, -10.1558329999999, -10.1397209999999, -10.135277, -10.125832, -10.1219439999999, -10.0841679999999, -10.073055, -10.06028, -10.0352779999999, -10.093056, -10.0808329999999, -10.101945, -10.0858339999999, -10.043613, -10.019723, -10.045833, -10.031943, -10.0874999999999, -10.1086109999999, -10.1174999999999, -10.1252789999999, -10.1152779999999, -10.139168, -10.1052789999999, -10.139168, -10.1475, -10.17861, -10.2041659999999, -10.188055, -10.1513879999999, -10.1608329999999, -10.1347209999999, -10.1230559999999, -10.093056, -10.129167, -10.1286109999999, -10.076945, -10.065278, -10.045833, -10.014166, -10.0202789999999, -10.0008329999999, -9.98027999999999, -9.95583399999998, -9.96749899999992, -10.001389, -9.99694499999993, -9.97694299999995, -9.96472299999994, -9.9775019999999, -10.024167, -10.0430569999999, -10.0369439999999, -10.0558329999999, -10.019167, -9.99527699999999, -9.96805499999994, -9.92472399999991, -9.89805799999999, -9.89083299999993, -9.84916599999997, -9.88250099999993, -9.829723, -9.80750099999995, -9.786945, -9.73305499999998, -9.69861099999992, -9.66970199999997, -9.62670899999995, -9.61059499999999, -9.55582499999997, -9.460083, -9.43579, -9.40972799999997, -9.38907699999999, -9.34228599999995, -9.31311099999999, -9.26580699999994, -9.25732399999998, -9.229309, -9.20326099999994, -9.11703199999994, -9.10367399999996, -9.06177199999991, -9.05200199999996, -9.01987299999991, -9.00280699999996, -8.98343799999998, -8.92575099999993, -8.86198999999994, -8.81500799999998, -8.80786999999992, -8.74828399999996, -8.66435899999993, -8.64421899999996, -8.62743499999999, -8.61149, -10.2463869999999, -10.235833, -10.2525, -10.261945, -10.266945, -10.3491669999999, -10.331388, -10.320833, -10.317501, -10.287501, -10.288611, -10.3069439999999, -10.353612, -10.3725009999999, -10.3919439999999, -10.4197219999999, -10.4313889999999, -10.4102779999999, -10.3836119999999, -10.3574999999999, -10.518056, -10.5063889999999, -10.5136109999999, -10.5524999999999, -10.563613, -10.5808349999999, -10.568612, -10.52861, -9.3641659999999, -9.36861199999999, -9.32821899999999, -9.33639199999999, -9.33325399999995, -9.30313299999995, -9.34266699999995, -9.34580499999999, -9.34015699999992, -9.30375999999995, -9.30250599999994, -9.31693799999999, -9.326979, -9.33952799999992, -9.33513599999998, -9.32258499999995, -9.27865900000001, -9.23455999999999, -9.22571499999998, -9.23174999999998, -9.28547399999997, -9.29452699999996, -9.29332099999999, -9.22933699999999, -9.226923, -9.23416599999996, -9.207607, -9.23416599999996, -9.24020099999996, -9.19674299999991, -9.16580599999992, -9.15373299999993, -9.19447699999995, -9.27974, -9.30533199999991, -9.32657799999993, -9.31643800000001, -9.33092699999997, -9.35796899999991, -9.3927369999999, -9.41156999999993, -9.464204, -9.48400299999992, -9.53373799999992, -9.567544, -9.59506999999991, -9.61631599999993, -9.64818699999995, -9.68198899999999, -9.72786299999996, -9.77035799999999, -9.78
Re: IRL-Admin1-XY
Hi Eugene,
The first one worked like a charm..but are there some brackets missing in this one as I'm getting an error! Thanks for all you help.
Cheers,
Rakhi
Stefan
Re: IRL-Admin1-XY
Add ]))) at the end of the script, it should work then
Stefan
Re: IRL-Admin1-XY
nopre, there is some missing data...
Re: Map of Ireland
The files are now on the JMP File Exchange, listed under "Add-Ins".
http://is.gd/oaBLWE
