LaserRasin
Keeping local scopes
I am trying to create a framework for visualizing data -- this leads me to create a template with several buttons that can act on the data that was passed into the template.
However, I am running into an issue with scoping where creating a button with a function to call -- calling this function happens in a different scope than where I would have thought based on the location of the button in the code.
I've provided a minimum working example below -- I would expect that when each button is clicked the resulting function call would happen within the original defining scope.
Is there a way to accomplish this?
Thanks!
Names Default To Here ( 1 );
insert_text = Function({tb, msg}, {Default Local},
	tb << Add ( "Added", msg )
tab_function = Function({msg}, {Default Local},
	Tab Box (
		"one",
		tb1 = Tab Box();
		V List Box(
			b = Button Box ( "Add", insert_text(tb1, msg))
		"two",
		tb2 = Tab Box();
		V List Box(
			b = Button Box ( "Add", insert_text(tb2, msg))
		"three",
		tb3 = Tab Box();
		V List Box(
			b = Button Box ( "Add", insert_text(tb3, msg))
New Window(
	"Test Window",
	tab_function("hi");
gzmorgan0
Re: Keeping local scopes
I am not sure what you are trying to do. But this is my  best guess. I modified a few things.
    tb << select;
    Caption(msg); wait(2); Caption(remove);
	tb << Sib Append (TextBox( msg ));
	tb << deselect;
 Eval(Eval Expr(
	Tab Box (
		"one",
		V List Box(
			   <<set Function(Function({this}, insert_text(this, expr(msg))) ) )
		"two",
		V List Box(
		"three",
		V List Box(
New Window(
	"Test Window",
	tab_function("hi");
LaserRasin
Thanks for helping!  However, this is not precisely what I am looking for -- I need to be able to reference variables local to "tab_function" from within the  "insert_text" function by passing a reference of said variable into the "insert_text" function.
gzmorgan0
Please notice in the previous script that the insert_text function is referencing the tab, tb,  and the msg, msg.  The <<Set Function passes the reference (this) the button and you can refererence its parent the VListBox or its parent<<parent, the tab.
First of all, I wouldn't use a function to create the tabs.  I modified the script to use tab page boxes and I create a variable or them.  Note since you are using a function, if you specify all variables but msg are local, the variable references will be unknown once tab_function runs. I commented our {Default Local}; uncomment it to see the errors.
I modified the insert_text function to demonstrate the script knows which tab button was pressed and you can get info about that tab page. Test each tab's button.
    tb << select;
    str = tb << get title;
    str = "I am on tab " || str || " with message " || msg;
    Caption(str); wait(2); Caption(remove);
	tb <<  Append (TextBox( msg ));
	tb << deselect;
tab_function = Function({msglist}, //{Default Local},
 Eval(Eval Expr(
  mytb= Tab Box (
   tb1=Tab Page Box( "one",
		V List Box(
			b = Button Box ( "Add", insert_text(tb1, expr(msglist[1])) )
   tb2 =Tab Page Box( "two",
		V List Box(
			b = Button Box ( "Add", insert_text(tb2, expr(msglist[2])) )
	tb3=Tab Page Box("three",
		V List Box(
			b = Button Box ( "Add", insert_text(tb3, expr(msglist[3])) )
New Window(
	"Test Window",
	tab_function({"hi","stay awhile", "goodbye"} );
//this command with throw an error with {Default Local}...once the tab_function runs tb1, etc are unknown
show( mytb << class name, tb2<<get title);
