ron_horne
Just love it when R2 comes out negative
Hi all,
Does anyone know what JMP does in the bivariate fit platform when calculating the “fit measured on original scale”? I just got a negative R2. Does it estimate a model without the intercept?
I know the data is peculiar and when using the log-log transformation I have many missing observations but still, something must be going on....
Attached is the data table with a script to reproduce the results I got.
Thanks,
Ron
jiancao
Re: Just love it when R2 comes out negative
Two modes, one fit to the original data and the other to the log-log transformed data, are different models. Anti-logs won't make summary of fit statistics from the log linear model identical to the results from the original linear fit.
14 REPLIES 14
jiancao
Your R Square is actually positive, but it is close to zero. When this happens, adjusted R square maybe slightly negative.  This is how adjusted R square formula is built to work. In fact, if R Square is <k/(n-1) , R Square Adj will be negative.
In your case, a negative R Square Adj. will occur when R Square <0.0013568. What a negative R square Adj. means is that the model terms do not help predict the response.
No,  it includes an intercept by default.
I would add that what a negative R Square Adj means is that the portion of variability of the predictors do not help predict the expected response. Thus, the R Square should not be used exclusively as the iron-fist to judge a model's anticipated performance. But it is also good for the R Square and the associated R Square Adj. to be positive.
Jenkins Macedo
ron_horne
thanks for the comment jiancao​
I must be missing something. where exactly does it say adjusted in the output?
jiancao
R Square Adj is the original R^2 adjusted for # of model terms in regression
ron_horne
sorry for the misunderstanding. i was referring to the R2 marked below.
jiancao
My apologies for missing the Fit Measured on Original Scale report. The attached table show where a negative R Square came from in this case. I saved the column Residuals Speed from the model fit (Notice that that it is calculated by taking Exp to back transform to the original scale). Then I calculated two Sum of Squares columns: SS of Total (SST) and SS of Error (SSE), for the R Square formula used by JMP, which is 1- SSE/SST=1- 164569257/115933657=-0.41951234.  So, the back transformation gives rise to a negative R Square.
ron_horne
Thank you jiancao​,
that did reproduce the negative figure. yet i would expect the figure to be identical to the outcome of fitting a line to the same data as in the picture.
but if i just run this with a fit line i do not get the same R2.
jiancao
ron_horne
I see, so how can i make use of the anti-log results? what are they comparable to?
