djhanson
How to get/read chart's y-axis max value?
For a given JMP chart (e.g. Variability chart, Box chart, etc) how to have JSL read in the chart's current y-axis maximum value?
Usually this is contained within SendToReport within a Dispatch (so I know how to change it in JSL).  But I'd like to read in the latest value in the event the user manually changes it by dragging the y-axis up/down with their mouse.
thanks, DJ
Re: How to get/read chart's y-axis max value?
Here is the example given in the Help==>Scripting Index, for Axis Box:
Open( "$SAMPLE_DATA/Big Class.jmp" );
biv = Bivariate(
      Y( :weight ),
      X( :height ),
      FitLine
rbiv = biv << report;
axisbox = rbiv[axis box( 1 )];
axisbox << Get Max;
You can also "Add Graphics Script" and in it check the yorigin and/or xorigin, along with the x and y range to trigger action taken when the axes are changed.
