sophiaw
Selecting Multiple Rows and Imputing a Value in a Column
I have a data table where I created an empty column, and I wanted to input values into that column based on the rows selected. I have a list of search parameters, and I can select which rows I want based on the list I input, but I just want to put the value of the list into the empty column for all the selected rows. I have most of the script working, but I just can't get the last part which is actually inputting the value into the new column for all the selected rows. Any suggestions?
group_gender = {"Male","Female"};
results << New Column("Gender", Character, Nominal);
For(i = 1, i < nitems(group_gender), i++,
     results << Select Where(Contains(:Names,group_gender));
     selRows = results << getSelectedRows;
     Column(results, Gender[selRows]) = eval(group_gender);
When I run this, I get an error "attempting to assign to an object that is not an L-value". Is there a way I can just change a column for all the selected rows to some value?
ms
Super User (Alumni) ms
Re: Selecting Multiple Rows and Imputing a Value in a Column
Use AsColumn(dt,col) for assignment and place the index outside the parentheses.
For( i = 1, i <= NItems( group_gender ), i++,
    results << Select Where( Contains( :Names, group_gender[i] ) );
    AsColumn( results, "Gender" )[selRows] = group_gender[i];
    // this works to:
    // results:Gender[selRows] = group_gender;
ms
    // this works to:
sophiaw
Thank you MS! I knew that last line had to be wrong, and that fixed it!
