fuscod
Community Trekker
Joining two Data Sets
JMP User Community - Thank you for your assistance in answering my JMP questions.  I have another question.
I am attempting to join two data tables by the field "Charge No"  the two data tables originated from SAP reports.  The challenge is that:
* In Data Set A the "Charge No" is:                      six numbers + 1 SPACE + four numbers
For example:  141922 0010
*  However in Data Set B the "Charge No" is:     six numbers + 7 SPACES + four numbers
For example 141922       0010
What I would like to do and my question is how to write JMP script that will Modify Data Set B so that the configuration of the "Charge No" is the same as in Data Set A i.e.  six numbers + 1 SPACE + four numbers
pmroz
Re: Joining two Data Sets
dtb = data table("Data Set B");
for (i = 1, i <= nrows(dtb), i++,
     dtb:Charge No[i] = substitute(dtb:Charge No[i], "       ", " ");
pmroz
fuscod
Community Trekker
Thank you!
Dan F.
fuscod
Community Trekker
Thank you – When I run this:
dtb = data table("Sheet1");
dtb:Charge No = substitute(a, " ", " ");
I GET THIS ERROR:
Name Unresolved: a in access or evaluation of 'a' , a/###/
pmroz
I corrected my syntax.  Should be
dtb:Charge No = substitute(dtb:Charge No, "       ", " ");
fuscod
Community Trekker
Thanks – That worked perfectly!
I’ve run into an issue that I don’t understand. I’ve used JMP code similar to that below to send a *.JPEG picture to a designated folder location in my computer (File Location\Charts). I’ve used code similar to this for over 5 years without issue and suddenly around 04/09/2015 the code no longer works? I’m not getting any error messages in the log but the picture is not being copied to the desired file location?
As I said I’ve used identical JMP code for years without issue and now it is not working. I’m wondering if this is somehow related to the recent renewal at about the same time this code stopped working of my JMP license.
See a copy and paste from the JMP Log below:
PathforMain = "C:\Users\fuscod\Desktop\Common\SAP Reports\15_04_08 LV1 SD MODs\";
PathforCharts = "C:\Users\fuscod\Desktop\Common\SAP Reports\15_04_08 LV1 SD MODs\Charts\"; (This is where I want to copy the Tabulate picture to)
CT = open(PathforMain || "LV1 SD MODS Planned vs Actuals-ES.jmp");
T1 = CT << Tabulate(
Add Table(
Column Table( Analysis Columns( :Planned Costs, :Actual Costs, :Delta Costs ) ),
Row Table( Grouping Columns( :Charge No, :Description ) ),
Row Table( Statistics( Sum ) )
T1 << Title("LV1 SD MODS ES Planned vs Actuals Costs");
/// Make HTML File for Dashboard
// Make Journal as Intermediary for Table
MyCJnl = New Window("DT",
<< Journal
T1 << Journal(freeze pictures);
MyCJnl << Save Picture(PathforCharts || "LV1 SD MODS ES Planned vs Actuals Costs.jpeg", JPEG);
MyCJnl << CloseWindow;
close (CT, nosave);
Hi, Dan.
Regarding your spacing issue...  The Collapse Whitespace() function became available in JMP 11.  The following will eliminate duplicate spaces within the values located in the Charge No column.
dtB = Data Table( "Data Set B" );
For Each Row(
  Column( dtb, "Charge No" )[Row()] = Collapse Whitespace( Column( dtb, "Charge No" )[Row()] )
Hope that helps!
Wendy
Wendy
fuscod
Community Trekker
Thanks for this information!
Dan F.
