BookmarkSubscribeRSS Feed
kaylesawyer
Nov 12, 2013
JMP Pro 11 Fit Model with list in JSL
Hi all,
I was trying to loop through a series of x variables ("Effects") for Fit Model, and came across this confusing behavior. When I create a list and use it with the Oneway platform, it behaves as expected. However, when I try the same thing with Fit Model, it seems to ignore my list and select variables based upon dt column order. I think this example code will make the issue more clear.
How do I specify an item from a list for an Effect within Fit Model?
data = Open ("$SAMPLE_DATA/Big Class.jmp");
x_list = {
  :sex,
  :height
data << Oneway(
  Y( :height ),
  X( x_list [1] )
data << Fit Model(
  Y( :height ),
  Effects( x_list [1] ),
  Personality( Standard Least Squares ),
  Emphasis( Effect Leverage ),
  Run(
  :height << {Lack of Fit( 0 )}
mpb
Jun 23, 2011
Solution
Re: JMP Pro 11 Fit Model with list in JSL
See if either of these does what you want:
eval(x_list [1])
or
eval(x_list)
mpb
Jun 23, 2011
Solution
eval(x_list [1])
or
eval(x_list)
kaylesawyer
Nov 12, 2013
Thank you mpb! The eval() command worked (as below).
data << Fit Model(
  Y( :height ),
  Effects( eval ( x_list [1] )),
  Run(
