tova
JMP 12 saving to PDF x-axis shifting
Hi.  I am trying to run the same script I used to run on JMP 11 on JMP 12.  It worked flawlessly on JMP 11.  I generate a lot of graphs, save them to a journal and then save the journal to pdf.  When JMP 12 saves the journal to PDF, it shifts the x-axis in the pdf.  The week number starts under the third bar instead of under the 1st bar.  Any idea why this is happening or what I can do to fix this?
Re: JMP 12 saving to PDF x-axis shifting
It sounds like a bug to me.  I would report it to
     support@jmp.com
so they can verify it, and if it isn't already known, get it in line to be fixed in one of the JMP 13 releases.
tova
thanks
