samayash
I am using EsriMap Convert to JMP addins under win7 and after reading the shape file it sits idle and no output generated.
Jeff_Perkinson
Re: I am using EsriMap Convert to JMP addins under win7 and after reading the shape file it sits idle and no output generated.
jeffmoore wrote that add-in.
I'm tagging him here to see if he can post some suggestions as to what might be going wrong.
-Jeff
-Jeff
jeffmoore
Hi Sam,  I'd like to ask a few questions:
  - What version of JMP are you using?
  - When you say "no output", do you mean no output is produced in the JMP log?  (you can view the log window by pressing Ctrl+L)
- Jeff Moore
jeffmoore
I posted an updated version of the ESRI to JMP Map Converter.  Download and install it to fix the problem.
The problem was caused by the converter not recognizing the columns in the shapefile, and the script would quietly conclude without converting the map.
I apologize for the difficulty this caused.  If you have any questions or concerns about the add-in, don't hesitate to post them in the comments on the add-in page.
-Jeff Moore
