BookmarkSubscribeRSS Feed
kofi
Sep 18, 2013
How to refer to a column with unknown name
Can anybody tell me how to send a column name (that I don't know beforehand and that will be determined while running the script) to a graph report, eg:
variable1 = "Metal";
name1 = "Width of " || variable1;
Overlay Plot(
    X( : Price ),
    Y(        : (Column (name1))  ),
This works to change line color:
    : Name ("Width of Metal") (Connect Color( 19 )
But I don't know the column name, because it depends on variable1. Therefore, I need to replace the expression  Name ("Width of Metal") and use the variable name1. I've tried
: Name (name1), : Column (name1), :name1      etc etc etc etc etc. Nothing works. But surely there's a way to incorporate a variable into the column name for the SendTo Command?
Regards,
Kofi
Jun 22, 2012
Solution
Re: How to refer to a column with unknown name
Here is the method I use:
variable1 = "ght";
name1 = "Wei" || variable1;
Eval(
      Substitute(
                  Expr( Overlay Plot(
                   X( :height ),
                   Y( __var__ ),
                    Separate Axes( 1 ),
                    Connect Thru Missing( 1 ),
                    __var__( Connect Color( 19 ), Overlay Marker( 8 ) ),
                    Dispatch(
                                     "Overlay Plot Graph",
                    FrameBox,
                    {DispatchSeg( Line Seg( 1 ), {Line Color( "Medium Dark Red" )} )}
            Expr( __var__ ), Parse( ":" || name1 )
pmroz
Jun 23, 2011
Overlay Plot(
    X( : Price ),
    Y( eval(name1) ),
ron_horne
Jun 23, 2011
try this:
variable1 = "ght";
name1 = "hei" || variable1;
Overlay Plot( X( :weight ), Y( Eval( name1 ) ) );
best,
ron
kofi
Sep 18, 2013
Hi guys,
thanks for reply. But the problem is not how to chose the column to create the overlay plot, but how to refer to the column to change the line colour etc in the graph.
: how_do_I_refer_here_to_the_column_in_order_to_change (Connect Color( 20 ), Overlay Marker Color( 20 ),  Overlay Marker( 20 )),
All the following option I've tried and they don't work:
: name1
: (name1)
: Column (name1)
: (Column (name1))
: eval (name1)
etc
: Column (1)  or : (Column (1))   doesn't work either, by the way.
Cheers,
Kofi
Jun 22, 2012
Solution
variable1 = "ght";
Eval(
      Substitute(
                  Expr( Overlay Plot(
                   X( :height ),
                   Y( __var__ ),
                    Separate Axes( 1 ),
                    Dispatch(
                    FrameBox,
kofi
Sep 18, 2013
Thanks Jim,
this does the job. Great!
Cheers,
Kofi
