twaintwist
How to overlay line plot on top of side-by-side bar chart?
I'd like to be able to create a chart like this2572_defect-arrival.png2572_defect-arrival.png   but I don't know how to overlay the line with the side-by-side bars -----     I have the data formatted to plot the line and I have a graph builder script to plot the line....
XanGregg
Re: How to overlay line plot on top of side-by-side bar chart?
Here's a quick example DT.
XanGregg
In Graph Builder use Date as X and use Active, Arrival, and Kill as Y. Then turn on both the Bar element and the Line element. Now you'll have three sets of bars and three lines. Right-click in the graphs and under each element's submenu use the Y menu to turn off the Ys that don't apply to that element.
twaintwist
xan --- thanks for the help ----    I'm still having trouble producing the graph ----   perhaps my datatable is not setup properly?
Could you provide a very brief table that would produce the chart?
In my table I have a date column, and a column for the number of defects that 'arrived' for  each date     and a column for the number of defects 'killed' for each data....
XanGregg
twaintwist
Xan,
Thanks ----  this made it clear ---- I was dragging In/out/Net to the right Y-axis and couldn't get it to work ---- but dragging to the left Y-axis worked....
