Theresa
How to only keep "day" information in the column after to time doing subtraction calculation
Below scripts, can't only get "day" and do not show the "hr:m"; Is there a way only get the day information? Ignore the information"hr:m"?
Scripts:
New Column( "Required Period 3",
Numeric,
"Continuous",
Format( ":day:hr:m", 14 ),
Input Format( ":day:hr:m" ),
Formula( :Target Completion - :Target Start ),
Set Selected
Data table is below:
Day is the only what i want after complete-start.
start                   Complete         Duration=Complete-Start          Change format       Day is what i need
2019-04-16      2020-03-31        30240000                                  :350:00:00               350
2019-08-01      2019-12-31       13132800                                   :152:00:00               152
Thierry_S
Re: How to only keep "day" information in the column after to time doing subtraction calculation
Have tried the Date Difference function in which you can specify the increment (e.g. "day", "week"...)
Date Difference( 01Jan2010:00:00:00, 27Jul2010:21:21:57, "Day", "fractional" );
Thierry R. Sornasse
Theresa
thanks for reply. But sorry, a little confuse. If there is over 300 rows with dates information need do this calculation. I need to change the start and complete format, then use use below script?
I try below but didn't work
New Column( "Required Period",
	Numeric,
	"Continuous",
	Format( "Best", 12 ),
	Date Difference( :Complete - :Start ),
	"Day",
	"fractional"
Thierry_S
Hi Theresa,
I don't have access to JMP right now but the interval "Day" should be within the Date Difference function
Numeric,
"Continuous",
Formula (Date Difference( :Start, :Complete, "Day", "fractional")),
Or something close to this
Thierry R. Sornasse
