statlover
Occasional Contributor
How to navigate from a term to a document row in Text Explorer SVD output?
We get two outputs when I do SVD, Topic Loadings (Term Vectors) and Topic Scores (Document Vectors). If I want to drill down on a particular term I select the desired term on the Topic Loadings list. I see that a particular data point gets selected on the SVD plots (Right side). So I click on the SHOW TEXT link to see the list of all documents that contain the term. This is a nice feature. But I would like to see the same list of documents (rows) also selected on the data table. Is it possible to directly navigate from a term to the table of documents where I can then subset that for further analysis?
Re: How to navigate from a term to a document row in Text Explorer SVD output?
Right-click on the term in the Term list and choose Select Rows.
statlover
Thank you very much Mark. I feel silly that I did not try that before :-)
