  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
Alida
Graph Builder: Y-Variable plotted as "Mean(Variable)" when adding a line to the graph
n/a
I have created a scatter plat with two different variables and my graph appears as expected. The issue is that when I add a line to the graph, this line is automatically associated with a summary statistic (the default is "mean"), even though none of the points actually need to be averaged. The graph displays everything as I would expect, so this wouldn't be a problem except the automatically generated graph title and legend all include something along the lines of "Mean(variable)".
If I right click on the line and navigate to summary statistic, I see that it can be changed - see screenshot. However, there does not seem to be an option to remove the summary statistic altogether for lines. [note that for points, there is a "none" summary statistic option]
Re: Graph Builder: Y-Variable plotted as "Mean(Variable)" when adding a line to the graph
Select the Row Order option for the Line
Alida
That worked, thank you!
