BookmarkSubscribeRSS Feed
uday_guntupalli
How to index files in a folder using a substr ?
All,
   When I have a folder with multiple files , how can I find the indices - to access these files using a common substr ?
For E.g. :
          If my folder has Ex1.jmp , Ex2.jmp , Ex3.jmp , AB.jmp.AC.jmp - I want to be able to search by Ex and get {1,2,3} as my index to access these files  .
Files = Files In Directory(Folder);
FilesIndex = Contains(Files,"Ex");
The above is the piece of code I tried
Best
uday
Best
Uday
Re: How to index files in a folder using a substr ?
When the Contains function is used with a list, there needs to be an exact match to a value in a list. When the Contains function is used with a string, it looks for a partial string within the larger string.
What you need to do is have a For loop that looks at each string in the Files list. See example below.
Files = Files In Directory( Folder );
FilesIndex = {};
For( i = 1, i <= N Items( Files ), i++,
If( Contains( Files[i], "Ex" ),
Insert Into( FilesIndex, i )
Justin
FilesIndex = {};
Justin
