sanchezpeinado
How to create a second Y axes scale?
I have 9 parameter and 4 of them have a low values (0 to 40) while the others 5 have values from 21 to 780. I would like to graph all together as seem below, but built a second Y axes for the first 4 parameters.
My data set (table) has the following columns:
     ID
     Time
     Parameter
     Data
10 REPLIES 10
Re: How to create a second Y axes scale?
Right click on the Y axis and select "Move Right" and then select which parameter to move.  Repeat for each parameter to be moved to a Right Side axis
