LeeP
How to Save Group By Charts Individually
I'm trying to automate my JMP chart creation. I've been using  the following as a guide: Automated Report Creation From Data Import to Publication 2019
I've gotten to the point where I can create all of the charts. Now I'm working on saving them and having a hard time determining how. I am generating a P Chart report that is grouped by some value in the underlying data table. The report comes out with multiple P Charts, one for each group by value. I want to save each one individually to a seperate HTML page. So for example, if I had a report that grouped on "Planets" and the report had charts for each planet, I want to have an HTML page with the chart for each Planet instread of a signle HTML page with all of the planets. Is this possible and if so, how. Attached is my sample script.
planetQ = New SQL Query(
	Connection(
		"CONNECTION INFO HERE"
	QueryName( "ON_TIME_SPC_PLANET" ),
	Select(
		Column( "ReleaseMonth", "t1", Numeric Format( "m/d/y", "-1", "NO", "" ) ),
		Column( "PLANET", "t1" ),
		Column(
			"On-Time",
			"t1",
			Alias( "Sum-On-Time" ),
			SavedJMPName( "On-Time" ),
			Aggregation( "Sum" ),
			JMP Name( "Sum-On-Time", 0 )
		Column(
			"Total",
			"t1",
			Alias( "Sum-Total" ),
			SavedJMPName( "Total" ),
			JMP Name( "Sum-Total", 0 )
		Column( "Phase", "t1", Analysis Type( "Nominal" ) )
	From( Table( "ON_TIME_SPC", Schema( "dbo" ), Alias( "t1" ) ) ),
	Group By(
		Column( "Phase", "t1" )
	Order By(
		Column(
			"ReleaseMonth",
			"t1",
			Numeric Format( "m/d/y", "-1", "NO", "" ),
			Order( "Ascending" )
) << Run Foreground();
planetQ << New Column( "OnTimePct",
	Formula( :Name( "Sum-On-Time" ) / :Name( "Sum-Total" ))
wait(1.0);
current data table(planetQ);
planetP = Control Chart(
	Sample Label( :ReleaseMonth ),
	Phase( :Phase ),
	Sample Size( :Name( "Sum-Total" ) ),
	KSigma( 3 ),
	Chart Col( :OnTimePct, P( Phase Level( "1" ), Phase Level( "2" ) ) ),
	By( :PLANET )
ian_jmp
Re: How to Save Group By Charts Individually
Here's an example you should be able to adapt:
NamesDefaultToHere(1);
// Get some data
// Run the platform. NB: ccb is a list, because of teh use of the 'By' variable
ccb = dt << Control Chart Builder(
						Show Control Panel( 0 ),
						Show Limit Summaries( 0 ),
						Show Capability( 0 ),
						Variables( Y( :height ) ),
						By( :sex)
// Save the report for each level of the 'By' variable
for(c=1, c<=NItems(ccb), c++,
	// Get the current report layer
	thisrep = Report(ccb[c]);
	// Get the first outline box
	firstOB = thisrep[OutlineBox(1)];
	// Get the title of this outline box
	thistitle = firstOB << getTitle;
	// Save as HTML
	firstOB << saveHTML("$DESKTOP/"||thistitle);
ian_jmp
// Get some data
						By( :sex)
	// Save as HTML
LeeP
I've tried the following, but it is not running properly:
current data table(ppn);
ppnP = ppn << Control Chart Builder(
	Phase( :Phase ),
	KSigma( 3 ),
	By( :name )
For( c = 1, c <= N Items( ccb ), c++,
	thisrep = Report( ccb[c] );
	firstOB = thisrep[Outline Box( 1 )];
// Save as HTML
	firstOB << saveHTML( "$DESKTOP/" || thistitle );
I get a single report like the following (note: I blacked out info) and nothing is saved as html to the desktop directory. I'm creating P charts, so don't know if that is an issue with this process.
ian_jmp
I doubt it's an issue with the type of chart. But I notice that you have assigned the reference to the multiple p charts from Control Chart Builder to 'ppnP', but the subsequent code still refers to 'ccb' (as I used in the example).
LeeP
Good catch on "ccb". That was part of the issue. The other problem was using "Control Chart Builder". I changed it to just "Control Chart" and it works. The new issue is the file name that is generated. I see you used:
This gives me a title name of: "Control Chart name=XXXXXXX"
1. I'm guessing that by using saveHTML, I could append .html since it is being saved without an extension.
2. How can I get get just the XXXXXX part? Would I have to know in advance that it will always be "Control Chart <Grouped by Field Name>=" and then manipulate that string value, or is there a simpler way? Are there string manipulation functions in JMP?
Jeff_Perkinson
There are many. Here's a good start:
JSL Character String Functions
If you learn only one Formula Editor function, Word() is the one
-Jeff
