BookmarkSubscribeRSS Feed
ben_irwin0
Not applicable
Sep 9, 2015
How do I send a variable list of columns to the Y grouping of the Variability chart?
Hi
I would like to send a list of columns to the Variability Chart. The list wouldn't have fixed amount of items.
dt = Open("$SAMPLE_DATA/Variability Data/2 Factors Crossed.jmp");
List = {:Measurement , :standard};
obj = Variability Chart( Y( List ), X( :Operator, :part# ) );
I would like it to function similar to this code where it would create them all in the same window.
dt = Open( "$SAMPLE_DATA/Variability Data/2 Factors Crossed.jmp" );
obj = Variability Chart( Y( :Measurement , :standard ), X( :Operator, :part# ) );
Right now I have it as a loop running for the number items and generating a separate chart for each column in the list in individual windows.
Thanks
ms
Jun 23, 2011
Solution
Re: How do I send a variable list of columns to the Y grouping of the Variability chart?
Try Eval(List):
obj = Variability Chart(Y(Eval(List)), X(:Operator, :part#));;
ms
Jun 23, 2011
Solution
Try Eval(List):
