Nazarkovsky
Hiding/unhiding preliminarily excluded rows from datasets
Dear colleagues,
I made a search over the topics here and did not see any discussion about the following issue: how to hide/unhide specifically excluded rows. The excluded rows are located randomly over the entire dataset (pic is enclosed) and I am sure that there must be a "single-click" command/option which enables hiding preliminarily excluded values. This function is desirable for graphs.
For your help I will be very thankful.
Michael
Reaching New Frontiers
Re: Hiding/unhiding preliminarily excluded rows from datasets
Go to the Rows Panel at the lower left hand side of the data table, and right click on the "Excluded" and select "Select Rows". Then go to any of the selected rows and right click on the rowstate column for one of the selected rows and select "Hide"
Nazarkovsky
Thanks a lot for such a brilliant response!
