BookmarkSubscribeRSS Feed
Hi. I'm programing JMP through VBA.
ysegal
Nov 2, 2014
Partial succes, yet I'm trying to define Axis minimum and maximum, the syntax not clear, can't seem to get the
AxisBoxNumericOption(,,) right. Please your kind help.
Many thanks,
Y.
briancorcoran
Jun 23, 2011
Solution
Hi Y.,
I'm attaching a code snippet to this reply, since this editor makes it hard to embed formatted VB code.  Basically, you have to obtain a handle to the axis boxes, and then use that handle for the other axis commands.  I hope the snippet helps.
Brian Corcoran
JMP Development
briancorcoran
Jun 23, 2011
Solution
Hi Y.,
Brian Corcoran
JMP Development
ysegal
Nov 2, 2014
Thanks Brian, this is exactly what I was looking for!
I'm a newbie to this forum, real good stuff here.
All the best,
Yosi.
