WineAroma
Graph Bulder "Wrap" using different column without "Stack"?
Hello Community!
I have a data below,
and I would like to create a graph like this without stacking the data. To create the image, I stacked "A-D."
Is there anyway to wrap by column?
I know how to stack 4 graphs on top of each other, but I like to see graphs organized in 2x2.
I'm using JMP 15.
Thank you!
Lei
Re: Graph Bulder "Wrap" using different column without "Stack"?
You can write a simple script to build a 2x2 where each of the subwindows are based on different columns, or you can build a dashboard to do the same.
WineAroma
Scripting and Dashboard are on my "JMP -Things to Learn" list.
But thank you! Good to know the answer is "no."
Cheers!
lei
WineAroma
I just learned (duh!) that if I use "Fit Y by X," I can get the similar graphs. Not as pretty, but good enough. Y=Rank, X=A, B, C, D.
Lei
