anne_sa
Graph Builder: reference line, different for each Y group
Hello everybody,
I would like to know if it is possible to define separated reference lines on the X axis when we have Y groups.
Here is an example using the BigClass data table.
I can define two reference lines, but I would like to display the red one only on the top graph and the blue one on the bottom graph.
Here is what I get:
Here is what I would like to get:
Is there a way to do that without playing with the menu Customize > Script ...?
Thanks in advance!
Level XIII
Re: Graph Builder: reference line, different for each Y group
and here an option with no JSL:
use a  "bar" graph  (with "float" style) with Response axis = X
View more...
"no JSL" - but here it is:
Names Default to Here(1);
// via right click - new formula column
New Column( "Mean[height][sex]",	Formula( Col Mean( :height, :sex ) ));
Graph Builder(
	Variables(
		X( :height ),
		X( :"Mean[height][sex]"n, Position( 1 ) ),
		Y( :weight ),
		Group Y( :sex ),
		Color( :sex )
	Elements(
		Points( X( 1 ), Y),
		Smoother( X( 1 ), Y ),
		Bar( X( 2 ), Bar Style( "Float" ), Response Axis( "X" ) )
ian_jmp
Level X
Graph Builder is designed to facilitate comparisons within and between groups. So, if you have multiple FrameBoxes from using grouping variables then, as you say, the x and y axes (and any reference lines associated with these) will always be common. So I believe the answer is 'no', not without resorting to JSL.
Level XIII
Fortunately, it's less JSL than one might expect:
right click / customize / + / type:
Level XIII
View more...
Graph Builder(
	Variables(
		X( :height ),
		Y( :weight ),
		Group Y( :sex ),
		Color( :sex )
	Elements(
		Points( X( 1 ), Y),
anne_sa
Hi @hogi ,
That's a very nice way to answer the problem, thanks! But if I understand correctly, it works only if we want to highlight a summary statistic value (mean, median...) and not a user defined threshold?
Level XIII
The basic step is
It can also be used for user defined thresholds. Jus store it in a column and plot it as Bar chart with Bar Style("Float")
anne_sa
Clear, thanks for your help @hogi !
