anne_sa
Graph Builder: reference line, different for each Y group
Hello everybody,
I would like to know if it is possible to define separated reference lines on the X axis when we have Y groups.
Here is an example using the BigClass data table.
I can define two reference lines, but I would like to display the red one only on the top graph and the blue one on the bottom graph.
Here is what I get:
Here is what I would like to get:
Is there a way to do that without playing with the menu Customize > Script ...?
Thanks in advance!
ian_jmp
Level X
Re: Graph Builder: reference line, different for each Y group
Graph Builder is designed to facilitate comparisons within and between groups. So, if you have multiple FrameBoxes from using grouping variables then, as you say, the x and y axes (and any reference lines associated with these) will always be common. So I believe the answer is 'no', not without resorting to JSL.
Level XII
Fortunately, it's less JSL than one might expect:
right click / customize / + / type:
