TamedZebra
Calculation Result Discrepancy, Col Mean, etc.
Why do calculation results differ when using variables compared to using direct strings? I suspect that when variables are used, the grouping function for the variable part might not be working. How can this be resolved?
with the following formula
Col Mean(
	:data,
	:A,
	:B,
	:C_D == "ccccccc"
This is the formula.
Col Mean(
	:data,
	:A,
	:B,
	Column(Eval Insert("C_^get_input_1^" == get_input_2))
Re: Calculation Result Discrepancy, Col Mean, etc.
Insert one expression into another using Eval Insert, Eval Expr, Parse, and Substitute
Most likely something like this, but I cannot test it as I don't have data or the earlier part of the script
dt = Data Table("data_table");
Eval(Substitute(
	Expr(Data Table("data_table") << New Column(colname,
		Numeric,
		"Continuous",
		Formula(Col Mean(:data, :A, :B, _input1_ == _input2_)),
	Expr(colname), Substitute(Xbar_^get_input_process^_^get_input_line^),
	Expr(_input1_) = NameExpr(AsColumn(dt, Eval Insert("new_^get_input_1^"))),
	Expr(_input2_) = get_input_2
8 REPLIES 8
TamedZebra
Sorry, everyone. I forgot to mention that get_input_1 and get_input_2 can be assumed to be already obtained as strings, respectively.
First one is comparing column vs string and second one we cannot be sure what is being compared (string to string which would always be 1 or 0?). At least it isn't evaluated and you will need to evaluate the values into the formula
TamedZebra
I want to achieve the same result as the expression in the first line. When the variables were given as get_input_1="D" and get_input_2="cccccc" respectively, I naturally expected the same result, but the reality was different...
Eval(Substitute(
	Expr(Col Mean(
		:data,
		:A,
		:B,
	Expr(_input1_) = NameExpr(AsColumn(dt, get_input_1)),
but you need to add new column and formula to that example
TamedZebra
Thank you for your replies. Also, I apologize for my late responses.
I wrote the JSL as shown below, but an error is being output. What could be the cause?
The error message says "insufficient arguments" at the location "Substitute/###/(Expr(".
	Data Table( "data_table" ) << New Column( Eval Insert("Xbar_^get_input_process^_^get_input_line^"),
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Formula(
			Eval(Substitute(
				Expr(Col Mean(
					:data,
					:A,
					:B,
	)) << Run Formulas;
Eval(Substitute(
		Numeric,
		"Continuous",
TamedZebra
 Thank you for your consideration, even though it was difficult to experiment without being able to provide actual data.
I modified it as follows to fit my data table.
Eval(Substitute(
		Numeric,
		"Continuous",
	Expr(colname), Eval Insert(Xbar_^get_input_process^_^get_input_line^),
	Expr(_input1_) , NameExpr(AsColumn(dt, Eval Insert("new_^get_input_1^"))),
	Expr(_input2_) , get_input_2
mmarchandFSLR
Column(Eval Insert("C_^get_input_1^" == get_input_2)) evaluates to Column( "C_D" == "ccccccc" ), so your formula would be
edit
Including non-string inside Eval Insert() actually causes it to evaluate to the empty string.
Col Mean(
	:data,
	:A,
	:B,
	Column( "" )
That may be why it isn't working as expected.  Jarmo's solution should be what you want.
