mad
mad
Gauge R&R Summary [SOLVED]
Is it possible to summarize the Gauge R&R results in a table?
I'm producing Variability Charts and Gauge Studies at several test frequencies:
Variability Chart(
Y( :DB21 ),
X( :Operator, :DEV_ID ),
Model( "Crossed" ),
By( :FREQ ),
where :FREQ contains 9 values. I would like to produce a table with columns like :FREQ, :EV, :AV, ::RR, :PV, TV:, :%Gauge R&R, etc.
Message was edited by: MAD
mpb
Super User mpb
Re: Gauge R&R Summary
This example may get you started. It creates 2 tables containing the info you want. To put it into the form you described you can transpose both tables appropriately and combine columns to get the results. This code assumes that each by-group has the same info entered in the secondary Gauge R&R dialog. You may have to work harder if that isn't the case.
mad
mad
Brilliant! Close enough for what I need. Thanks.
